Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-10-2009, 03:49 AM   #1
StriderTacticaL
Vehicle: '04 Mustang GT
Default Bottom line for correct fluid for TR-3650?
Soon after I first bought my car, I installed an MGW. I basically ended up having problems with with not banging into 3rd and some people have said the same about their MGW's. I was also told to change my tranny fluid as it might have helped. Well I put in 3.2 quarts of RP synchromax and have been running it ever since. I recently sold my MGW and put in a Hurst which I love but it still feels the same way as my MGW did in terms of it not being smooth and being a bit tough. Particuarly, it was kinda alarming when the buddy I sold my MGW to installed it and when I tried it out in his car, it felt totally different.
Also, eariler tonight, I was out driving around. I basically gunned it from a light and when I tried to bang into 2nd, it grinded heavily. It happened again when I gunned it on the on-ramp to the freeway. It doesn't happen all the time but the toughness it always there.
I've heard that RP synchromax may be the wrong fluid for the 3650. I keep hearing things about Mercon 3, Mercon 5, and stuff like Mercon 3 being discontinued.
Does anyone know what the proper fluid is for the 3650? Can I even go back to regular seeing that I already have RP synchromax in it? Is it worth a shot trying another fluid and exactly which one should I buy?
Thanks,
Brandon
__________________
04 GT
K&N FIPK, Accufab 75mm TB & Trickflow plenum, Bassani SS catted X, Borla Stingers, 31 spline T-Lok w/Moser axles, FRPP 4.10's, Hurst billet/plus, MM XD LCA's, MM XL FLSFC, Cobra brakes, Sniper tuned.
StriderTacticaL is offline   Reply With Quote
Old 08-10-2009, 08:08 AM   #2
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Vehicle: 01 Lightning
Ford calls for Merc V in the 3650...
Your shifting issues sounds like a case of bad synchros, which is very common for the 3650 to do.... 2nd and 3rd gear
__________________
RESIDENT FORD TECH
`01 Lightning ----- FOR SALE http://mustangforums.com/forum/other...-for-sale.html
Stiegemeier stage 4 blower. LFP ported intake, Accufab TB, #6 pulley, 60# injectors, MAFia, Art Carr converter, JLP intake + traction bars, Magnaflow catback, AFCO h/e, LC1/XD16, SCT tuned by Matt @ Performance Evolution 448hp/508tq
WhiteFoxGT is offline   Reply With Quote
Old 08-10-2009, 08:44 PM   #3
StriderTacticaL
I think it was specificially stated to NOT use Mercon V in the TR3650...at least in the pre-05 ones. So no one knows???????????
__________________
04 GT
Old 08-10-2009, 09:08 PM   #4
steve0914
steve0914's Avatar
he is a ford technician....
__________________
2003 bolt-on GT- TOTALED
2006 F150 Chrome- New whip
steve0914 is offline   Reply With Quote
Old 08-10-2009, 09:19 PM   #5
StriderTacticaL
In regular driving and 95% of the time when I bang gears, everything seems to be fine...sometimes shifting to 2nd/3rd is a bit louder as in I can hear the synchros thats it. Basically the shifting just feels like there is more resistance than there should be.
__________________
04 GT
Old 08-10-2009, 10:10 PM   #6
cliffyk
cliffyk's Avatar
Tremec's most recent 3650 service manual says this:
That said, I have run Royal Purple Synchromax for over 60k miles with no problems..
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 08-11-2009, 01:36 AM   #7
Chubstang
Chubstang's Avatar
Vehicle: 2002 GT
Send a message via AIM to Chubstang
I used Mobil synthetic ATF.
While we're on the subject of transmissions, has anyone else noticed the tranny getting pretty warm after driving for a while? I can feel the heat radiating off the tranny after 20-30 minutes of city driving.
__________________
02 GT 5 spd.
-JLT RAI, MRT Catted H, SLP LM1.5 CB, MGW STS, C Springs,
Tokico HP's, MM FLSFC's
Chubstang is offline   Reply With Quote
Old 08-11-2009, 03:16 AM   #8
Frostbitten
ive been using b&m trick shift without a problem
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Old 08-11-2009, 07:58 AM   #9
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
2004 Mustang Workshop Manual General Specifications Item Specification
Lubricants and Sealants
Motorcraft MERCONŽ Multi-Purpose (ATF) Transmission Fluid XT-2-QDX
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE:
MERCONŽ Automatic Transmission Fluid is being replaced by MERCONŽ V as a service fluid.
ACTION:
Beginning immediately all automatic transmission / transaxle applications requiring MERCONŽ can now be serviced using MERCONŽ V or MERCONŽ Automatic Transmission Fluid or dual usage fluids labeled MERCONŽ / MERCONŽ V. After July 1, 2007, MERCONŽ Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCONŽ with MERCONŽ V or MERCONŽ Automatic Transmission Fluid or dual usage fluids labeled MERCONŽ / MERCONŽ V
For proper fluid application on current and past model vehicles equipped with automatic transmissions / transaxles refer to the fluid usage chart. (Figure 1)
CAUTION: AUTOMATIC TRANSMISSIONS / TRANSAXLES THAT REQUIRE MERCONŽ V SHOULD STILL ONLY USE MERCONŽ V OR DUAL USAGE FLUID LABELED MERCONŽ / MERCONŽ V.
CAUTION: MERCONŽ SP, MOTORCRAFT PREMIUM AUTOMATIC TRANSMISSION FLUID AND MOTORCRAFT M5 ATFS ARE UNIQUE FLUIDS AND MUST BE USED IN APPLICATIONS RECOMMENDING THAT PARTICULAR FLUID. USE OF ANY OTHER FLUID MAY CAUSE REDUCED FUNCTIONALITY OR TRANSMISSION DAMAGE.
CAUTION: THE FUNCTIONAL CHARACTERISTICS OF FLUIDS FOR CVT TRANSMISSIONS ARE VERY DIFFERENT THAN THOSE OF OTHER AUTOMATIC TRANSMISSION FLUIDS (ATFS). USE OF A FLUID OTHER THAN MOTORCRAFT CONTINUOUSLY VARIABLE CHAIN TYPE TRANSMISSION FLUID OR ONE LABELED AS MEETING MERCONŽ C WILL CAUSE FUNCTIONALITY CONCERNS AND INTERNAL TRANSMISSION DAMAGE.
CAUTION: DO NOT USE AUTOMATIC TRANSMISSION FLUID SUPPLEMENTS, ADDITIVES, TREATMENTS OR CLEANING AGENTS.
PART NUMBER PART NAME
XT-2-QDX MERCONŽ (Quart)
XT-2-DDX MERCONŽ (55 Gal. Drum)
XT-5-QM MERCONŽ V (Quart)
XT-5-DM MERCONŽ V (55 Gal. Drum)
WARRANTY STATUS:
Information Only
With that being said, I used Merc V in my cars and other Mustangs no issues. Im just goin off what I was told thru Ford. Hasnt let me down yet. The Mobil 1 ATF is probably better fluid, but Im just giving out OEM information Also, I dont think I have ever billed out the XT-2 on any ticket. So maybe I've been putting the wrong fluid in cars for years?
__________________
RESIDENT FORD TECH
Old 08-11-2009, 01:43 PM   #10
cliffyk
cliffyk's Avatar
How is that TSB at all relevant to a 3650 5-speed?
__________________
-cliff knight-
My Mustang
2010, 3650, bang, change, fluid, gear, gt, merkontr, mustang, oil, put, recommend, recommended, tr3650, tremec
Featured Sponsors
New Sponsors
Š Internet Brands, Inc.
