Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-19-2009, 12:33 PM   #11
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Vehicle: 01 Lightning
I dont think this car is applicable to the ETC system that the description of the code gives.. I believe thats based on car with drive-by-wire throttle, which the didnt start on Mustangs until 2005.
I would say that the PCM is probably shorted internally. Only thing I can think of that will destinguish between a bad PCM and/or bad Handheld would be to try and re-program the PCM with a Ford scanner. But this may not be achievable because you cannot set the PCM back to stock from the SCT. So I'd say start looking for a PCM to swap and test
__________________
RESIDENT FORD TECH
`01 Lightning ----- FOR SALE http://mustangforums.com/forum/other...-for-sale.html
Stiegemeier stage 4 blower. LFP ported intake, Accufab TB, #6 pulley, 60# injectors, MAFia, Art Carr converter, JLP intake + traction bars, Magnaflow catback, AFCO h/e, LC1/XD16, SCT tuned by Matt @ Performance Evolution 448hp/508tq
WhiteFoxGT is offline   Reply With Quote
Old 08-19-2009, 12:42 PM   #12
stang04chris
Vehicle: 2004, mustang,gt
Ok could this be done at a normal shop or will I have 2 take it to a mustang shop
stang04chris is offline   Reply With Quote
Old 08-19-2009, 12:50 PM   #13
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Can what be done?? PCM swap?? You have to find a PCM to use first. A new one will cost your a fortune.
A PCM swap is pretty straight forward, no prior programming needed like the newer cars. Just yank the passenger sill plate, kick panel, disconnect and move the 3 big connectors in the way, remove that bracket, unbolt the PCM harness from the PCM (10mm) then take the PCM hold down bolt off.
__________________
RESIDENT FORD TECH
Old 08-19-2009, 12:58 PM   #14
stang04chris
Could I use any pcm from a 99-04 gt, or one specifially for an 04 5speed gt, and where could I get one
Old 08-19-2009, 01:09 PM   #15
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Now that question Im not so sure on. Technically, any 5 speed 99-04 PCM will work.. So I want to say yes. I do know that auto PCMs wont work right
__________________
RESIDENT FORD TECH
Old 08-19-2009, 01:20 PM   #16
stang04chris
I found some on ebay for about 100 used, if I swap it out will my programer work with the new one or will I nedd to get a new
Old 08-19-2009, 01:33 PM   #17
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
There lies a new problem. You cant retrieve the tune off the PCM and put the stock one on can you? Your handheld is now locked to your old PCM. Thats on you now... Might have to call SCT up on that one
__________________
RESIDENT FORD TECH
Old 08-19-2009, 01:36 PM   #18
stang04chris
Well me and a buddy where thinking about goin in on sniper together, so if I entirely replace the pcm that would fix it right
Old 08-19-2009, 01:48 PM   #19
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
The sniper software doesnt replace the PCM... So you will need one anyway. Im not saying that your PCM is 100% dead, Im telling to you swap it with a known good one and see if the problem persists
__________________
RESIDENT FORD TECH
Old 08-19-2009, 02:18 PM   #20
stang04chris
Ok, I understand sniper won't replace it but if the sct is messin everything up it gives me a reason to replace it, and just to make sure, the pcm will not have to be programmed right, it will just bolt in correct
code, codes, communication, engine, error, f150, fix, ford, musang, mustang, p0606, pcm, repair, threw, trouble
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
