Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-29-2009, 12:15 AM   #1
ron555
Vehicle: 2003 Mustang, GT
Question radiator fan motor 2003 4.6 won't start
i replaced the whole radiator fan, motor assembly with a new assembly on my 2003 GT 4.6 Liter, dual overhead cam & replaced a burnt 50 amp fuse. all the other fuses are fine. now the radiator fan only turns on when i turn on the air conditioner. it does not turn on when the motor heats up, as it's suposed to. the air conditioner does not produce cold air. i also replaced the cooling sensor but it didn't help. the dealer says it may be many things. the computer chip is not communicating with the new radiator fan & needs an adjustment. an aluminum wire is burnt. the PCM (power control module) has to be changed $192 or the CCRM (constant control relay module) has to be changed, $625 dealer price. any ideas.
ron555 is offline   Reply With Quote
Old 08-29-2009, 01:25 AM   #2
SirKnightTG
2006 Ford Mustang
SirKnightTG's Avatar
Vehicle: 2006 Mustang GT Premium Auto - Vista Blue
You might have better luck here: http://mustangforums.com/forum/4-6-modular-mustang-7/
This is the 2005+ section.
I know it's not at all obvious with how the sub-forums are laid out on the "Ford Mustang Tech" page. MF should really make it more obvious which forums belong to what generation.
__________________
Boomtube crew
TCI StreetFighter crew
Kooks crew
FRPP Hot Rod crew
camthumpinstang (Gary Marine of Illinois) is a scammer!
SirKnightTG is online now   Reply With Quote
Old 09-24-2009, 09:19 PM   #3
Dalton Gang
Vehicle: `65 - `85 - `03 mustangs
I have the exact same problem and am thinking that the fan relay that's controlled by the temperature sensor is fried but I don't know where it is.
Can someone please tell me where the fan relay is?
Dalton Gang is offline   Reply With Quote
Old 09-25-2009, 02:04 AM   #4
Frostbitten
there is a cooling fan resistor that plugs into the top of the fan shroud. It controls the speed of the fan. If its broken that could cause your fan not to come on when its supposed to. The fan is supposed to come on at low speed when your just driving around town. Its only supposed to come on high speed when the coolant temps get really high
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
2002, 2003, 46, assembly, cobra, controls, cooling, dual, fan, fans, fuse, gt, motor, mustang, radiator, s197
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
