i swapped my T-45 for cobra T-45 and from what i heard it needs almost 4 quarts of trans fluid, so i asked my friend(he swapped he's auto to 5 speed by himself) and he said that i should pour it in until i see it in the shifter boot. so i poured 4 out and it wasn't anywhere near, then i bought 2 more quarts and poured them in. so now i can barely see that there's some fluid through the shifter boot (in that little hole in there). then my other friend told me that it's obviously too much and i should pour some out otherwise i'll blow a seal out.
so what should i do? level it with the top bolt on a side of the trans?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
hmmm.. im not sure about the t45 but im pretty sure the t3650 is 3.2 quarts i believe... i know this is no help to you but it just gives u an idea.. 6 sounds like a lot compared to 3.2
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
Things to do:
1) Fix exhaust leak
2) Remove isolators
oh wow, thanks
i'm assuming regular t-45 should have the same amount as cobra t-45
in specs it says that they're known to grind when cold, mine doesn't. feels like it's freshly rebuilt, love the swap
well, drained extra fluid today. leveled it to the top plug.
and decided to take if for a spin, roasted my tires through 3 gears lol. ridiculously awesome
Things to do:
1) Fix exhaust leak
2) Remove isolators
