When cold the my cars grinds a little bit in 1st & 2nd
When I first start my 96 GT in the morning, it usually grinds a little getting into 1st and 2nd, it seems as though as it warms up I don't have the problem, do i need a new tranny?. Its got 114k and I put a steeda Tri-Ax in it on Sat. I don't know what the service records are for the car as I just got it and am the 3rd or 4th owner.
On another note I was getting a miss fire in the 3rd and 5th cylinders, I changed the plugs and the light went away and the drive ability of the car is a night and day difference.
One last thing, if the intake manifold in my 96 has the aluminum crossover in the front then that means its been changed to the newer one right?
thanks
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
At least, that`s the short version. Anyway, mine tends to grind if you shift too quickly before reaching OT on the colder days, but it`s really nothing to worry about. Your synchros will be all right, just take it easy
__________________
Red 1996 GT
PI Swapped
BBK Shorty Headers
Pypes HFC'd X Pipe
Magnaflow Catback
Fender-Well CAI
Hurst Billet Aluminum Shifter
Rear Window Louver
Drilled/Slotted Rotors with High Perf. Pads
Hood Pins!
Sequential Tail Lights
Awful Looking Stock Rims Painted Gun-Metal
Mine the complete opposite.It shifts perfect when its cold but after 10 minutes of driving I am screwed.It sucks when some homo in a 4 banger tries to pass me on the freeway and I cant down shift to keep them from doing it.haha
__________________
CMS stage 2's,comp springs,and Bullitt intake waiting for install.
Looking for focus fuel pump and ported heads.PM me if you have any.
My TR 3650 always goes into 2nd rough when its cold out. It never grinds when I shift during WOT @ 5200 rpms though. My car has 50,000 miles and I'm thinking about just buying a rebuild 3650 off of ebay for $700.
__________________
2004 mustang GT
MGW shifter
JLT RAI
I'm seriously considering just swapping in a T56, I had an 01 Z06 (RIP ) and it shifted beautifully no matter what. When I get the money its either gonna be that or PI heads, cause it seriously pisses me off when first thing in the morning I have to deal with gears grinding.
Is your fluid level correct? What type of fluid are you using? This should not be happening.
__________________
2000 GT 5 Spd
BBK Fenderwell, Trickflow 75mm Plenum, Summit 75mm TB, Steeda Triax, King Cobra Clutch, FRPP Flywheel, Steeda Cable Adjuster/Quadrant, SLP catted X-pipe, SLP LM1 exhaust, Sniper SF Tuning, Weld in Full Length SFCs, FRPP 4.10 Gears, Carbon Clutch Discs.
Wish list....
KB blower
Rear suspension-UCAs & LCAs in a box-need a free weekend to install
Tubular front suspension
Long tubes
thanks
How long has it been doing this grinding in 1st and 2nd? Did you check the fluid level when you changed your shifter? Too little fluid could cause this.
__________________
2000 GT 5 Spd
Wish list....
KB blower
Long tubes
