Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-13-2009, 08:08 PM   #21
CopNaStang
Vehicle: 2004 Mustang GT Coupe
Make sure all connections on your intake are nice and tight, and check for any other vacuum leaks. That will stall it out while driving in a heartbeat
__________________
2004 Mustang GT, 5 spd, Shadow Grey, 14K original miles.
CopNaStang is offline   Reply With Quote
Old 09-13-2009, 08:34 PM   #22
cliffyk
cliffyk's Avatar
Quote:
Originally Posted by SVTeeshirt View Post
cliffy it was an OEM maf, nothing sounded like it was gonna die, it never burned oil, i never had to add a quart between changes as long as i remember.
Then what makes you feel it's on its last legs?
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 09-13-2009, 11:24 PM   #23
SVTeeshirt
Vehicle: 1996 Mustang Cobra
Quote:
sorry 2 seprate people in here with same cobras think we got a little confused lol we have the same problems except his is burning oil ( i think) mine isn't, just tired of spending $ on sensors and stuff and it isn't fast enough lol.
__________________
Fastest Closet on MustangForums.
I bought a goldfish, named it after my ex-girlfriend, and let it die. It's really the little things in life.
SVTeeshirt is offline   Reply With Quote
Old 09-15-2009, 03:23 PM   #24
disposablehero27
disposablehero27's Avatar
Vehicle: 1996 SVT Cobra
yeah mine does burn oil... and cliffy that throttle body fixed er right up. thanks man, have a new IAC out of the deal.. oh well. she's running pretty true it seems. I'm still getting some kind of popping and backfiring when the motor has drag on it, like going down hill in a low gear, it pops and crackles. Others say it shouldn't be a problem, something like unburned fuel or something. should i worry?
__________________
1996 SVT Cobra
*FRPP4.10's
*cold air intake
*superchips tuner
*FRPPaluminum driveshaft
*straight pipes no cats flowmasters
*Black cobra floor mats
*chrome fuel door
*Accufab1600cfm throttle body
*Chrome appearance hood pins
*Steeda Tri- axShort throw shifter
disposablehero27 is offline   Reply With Quote
Old 09-16-2009, 02:33 PM   #25
EODMustang
2001 Ford Mustang
EODMustang's Avatar
Vehicle: 2001 Ford Mustang GT
I would suspect the TB is not bleeding enough air at closed throttle (I.e. it's closing too tightly) and the IAC cannot compensate for the "chopped off" air flow quickly enough--try tweaking the throttle plate stop screw, making it more open in 1/8th turn increments.
You need disconnect the battery for 5-7 minutes between adjustments to reset the KAM, and let the engine idle for at least 15 minutes after restarting...
Will disconnecting the battery for that long reset the ECU to stock parameters? I was just wondering if I would have to re-flash the ECU with my Diablo after I did that.
EODMustang is offline   Reply With Quote
Old 09-16-2009, 04:03 PM   #26
devongarver
devongarver's Avatar
Vehicle: 2000 Mustang Gt 5 speed
Quote:
^^That's normal, its called backfiring. Just unburnt fuel reigniting as it exits through a hot and very open exhaust.
Quote:
No, when you "flash" a tune into the ECU, you are flashing a EE-PROM chip. It only can be changed by adding electrical charge, in a controlled fashion of course, or UV light over the window which obviously isn't going to happen. It will not change due to battery failure. The information that is lost is a seperate circuit of parameters. So, no worries.
__________________
2000 GT 5 Spd
BBK Fenderwell, Trickflow 75mm Plenum, Summit 75mm TB, Steeda Triax, King Cobra Clutch, FRPP Flywheel, Steeda Cable Adjuster/Quadrant, SLP catted X-pipe, SLP LM1 exhaust, Sniper SF Tuning, Weld in Full Length SFCs, FRPP 4.10 Gears, Carbon Clutch Discs.
Wish list....
KB blower
Rear suspension-UCAs & LCAs in a box-need a free weekend to install
Tubular front suspension
Long tubes
*COP STICKY*
devongarver is offline   Reply With Quote
Old 09-20-2009, 12:13 AM   #27
EODMustang
2001 Ford Mustang
EODMustang's Avatar
Thanks Devon
Old 09-20-2009, 12:53 AM   #28
Evenexchange
Vehicle: 2000 Mustang GT
What happens if you turn that nut on the TB too much and cause the flap to open up too much?
Evenexchange is offline   Reply With Quote
Old 09-20-2009, 01:06 PM   #29
cliffyk
cliffyk's Avatar
Quote:
Depending on how much too open the "flap" (aka throttle plate) is open, returning to idle will be sluggish, or not happen at all because even with the IAC "off" there will be too much air flow...
__________________
-cliff knight-
My Mustang
Old 09-21-2009, 08:54 AM   #30
devongarver
Just a side note: I adjusted mine over the weekend, and reset the KAM, and WOW what a difference it made....for about a few hours of driving...
It was fantastic, didn't dip in the RPMs at all when coming to a stop, and it definitely fixed the "catch" in the pedal at tip in. But as the ECU beagn relearning, it slowly started resorting back to how it was. It mechanicly works well still, the catch is still gone so the pedal application is smooth as butter. BUT, it almost stalled on me again when I was stopped in the driveway. It just dips low in the rpms, sometimes down to 350-400. And this was not happening for the first few hours of driving. I am wondering what the computer is learning that would cause this. I am thinking before next season(since its being garaged in a month), that I will replace the battery and alternator, as well as the wiring too and from. They are all original, and I am getting a leak somewhere because I am getting corrosion very quickly on the negative terminal even with dielectric on it. Any thoughts?
__________________
2000 GT 5 Spd
Wish list....
KB blower
Long tubes
*COP STICKY*
06, 40, air, cai, car, cold, foot, ford, gas, iac, idle, intake, mustang, noisy, roush, shuts
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
