Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-29-2009, 06:59 PM   #1
572ysc
572ysc's Avatar
Vehicle: 1999 Ford Mustang GT Convertible GRN
Default RWHP seem right?
So I have a 1999 Mustang GT with a manual and 3.27 gears.
It has a SLP catback LM1 and stock cats, no mods.
NGK V-powers spark plugs with 12.000 miles (i know their due to change)
It pulled 220 rwhp and 263rwtrq with no fan in front of the car is that a decent number?
Vehicle has 158000 miles if that matters much.
__________________
1999 Mustang GT Convertible 4.6 SOHC 5-Speed
Mods: Torque Thrust M 17x9(Summitumo 245/45/17), 17x10.5(Summitumo 315/35/17), 10th Anniversary Cobra brake conversion, SMR Strut tower brace, MM Caster-Camber plates, Strange adjustable front struts, UPR coilover kit with 350lb QA1 springs
SLP catback LM1
Video: http://www.youtube.com/user/427ysc#p.../1/riCtVXHWOW8
More launches on youtube under member: 427ysc
Cruisen on the Street rippin on the track.
572ysc is offline   Reply With Quote
Old 09-29-2009, 07:07 PM   #2
TRUEBLUE3934
Vehicle: 2001 Ford Bullitt Mustang
Do you know if it was measured on a Dynojet or Mustang dyno? I was just having a discussion on the Bullitt Mustang forum and I was told a Mustang dyno would read 12% lower than a Dynojet dyno.
This 12% figure sounds to big to be true, so I am looking for other input before I 100% believe it myself.
For the record, the stock 2001 Bullitts pull about 235rwhp on a Dynojet dyno.
TRUEBLUE3934 is offline   Reply With Quote
Old 09-29-2009, 07:24 PM   #3
572ysc
572ysc's Avatar
Oh ok thanks for the info. I dont know whats the difference? It was a ground installed one. Also would 44psi rear tire pressure have effect on the readings? Thanks for the info.
__________________
SLP catback LM1
Old 09-29-2009, 07:49 PM   #4
945LSTANG
945LSTANG's Avatar
Vehicle: 2003 SVT Cobra
those numbers are about right. theyre actually not bad at all considering the age of the car and the amount of miles on it. i would be happy with the results.
__________________
03 Cobra
94 GT - R.I.P. 11/30/08
Quote:
Originally Posted by casper_stang View Post
take in consideration the area where you live. where i live all cobras get stolen thats why i bought the GT
945LSTANG is offline   Reply With Quote
Old 09-29-2009, 08:10 PM   #5
cliffyk
cliffyk's Avatar
Those are typical numbers for a mostly stock '99--'04 GT, running the OEM tune. I have seen 5 or 6 of these dynoed (including mine*), with peak rwHP numbers ranging from 209 to 225 HP (a Bullitt).
A mail-order or canned 93 octane tune would get you up to 235 or so, with noticeable improvement in the mid-range as well. Add a 70mm TB and aftermarket upper plenum, and tweak the tune to add timing at WOT and get the AFR dialed in, and you'll be into 245 to 250 peak HP--and be able to pull strongly right up to redline.
Also, and unless you just like changing spark plugs, get a set of platinum plugs. The NGK V-Power plugs offer nothing but more frequent changes for most any n/a application--very high-compression engines being the only exception.
* - The first time I dynoed mine, a couple week after I got it, it did 220/243 with a really crappy eBay special CAI, an o/r H-pipe, and Flowmaster 40's welded in to the stock pipes.
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is online now   Reply With Quote
Old 09-29-2009, 08:46 PM   #6
massred98gt
Vehicle: 1998 ford mustang gt
ya those are exactely right. you don't have any power mods. i mean thats right around stock give or take a few hp. i would be happy with those numbers. your stang's running stong in its old age
__________________
rio red 1998 gt:
Mods:
bbk cold air intake, 75mm t/b and a&l plenum, udp, pi intake manifold, bullet stage 2 cams, ported npi heads, bbk shortie headers, slp catted-x, loudmouth 1's, 3.73 gears, eibach prokit with steeda cc plates, agx struts, subframe connectors, plenty more to come!!!
276rwhp/299rwt
"DRIVE IT LIKE YOU STOLE IT"
massred98gt is offline   Reply With Quote
Old 09-29-2009, 08:55 PM   #7
0949er
Vehicle: 2004 Mustang GT
ok... so i have a quick questions... so WTF is a mustang dyno?
I mean, I know that "dyno" is when you calculate wrHP with how fast you rotate the drum that the wheels spin on (in simplified terms)
but wtf is a "mustang" dyno? and all this conspiracy that some dynos are "incorrect" and "not accurate"?
I have never seen/heard of a mustang dyno/dyno jet... all I have heard of is a shop, that has a dyno in their floor, which is just a steel drum that spins and based on rotation speed and drum weight, etc, it calculates how strong the motor is.
I'm assuming mustang dyno and dyno jet are independent companies that sell the "dyno" setup for shops?
can somebody explain this to me.
__________________
MODS:
Comp Cam Stage 2's (XE 270AH)
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
288 wrhp / 310 wrtq (Tune by Pro-Dyno.net)
"Supercharger Turbonator Stage 2"
NEW VIDEOS!!!
In Progress:
Vortech V-1 T-Trim 60% Parts, 0% Install
0949er is offline   Reply With Quote
Old 09-29-2009, 09:02 PM   #8
cliffyk
cliffyk's Avatar
That's it, you just answered your own question--read the wikipedia article on dynamometers so that you might understand there are different types that produce different results. Then Google "Mustang dyno" and "DynoJet"...
__________________
-cliff knight-
My Mustang
Old 09-29-2009, 10:33 PM   #9
mrtstang
Vehicle: 2004, Ford, Mustang Gt
Those numbers sound about right. Maybe a tad low, but definantly in the normal range.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is offline   Reply With Quote
1999, 2001, 2010, 310, cobra, dynojet, fox, gt, iv, mods, mustang, rwhp, saleen, series, video
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
