Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-10-2009, 02:59 AM   #1
spencwad
Vehicle: 2000 Ford Mustang GT Conv
Default Crankshaft pulley bolts
So i decided to do my crankshaft pulley. I purchased the Steeda pulley kit. When I went to take the bolt out of the pulley, it was hand tight and was able to just spin it out with my hand. For some reason, the bolt that I got with the kit was actually shorter than my 'stock' bolt, which leads me to believe that my 'stock' bolt isn't actually stock. Then sure enough, I screwed my threads up pretty bad on both of the bolts and can't really tell if the threads on the inside are messed up or not. Don't really know my options, so I would REALLY appreciate it if some of you guys would give me some advise. Like the dimensions/size of the stock bolt and where I would be able to purchase it at, and if my threads are screwed on the inside, what i should do next.
Thanks for anyone's help i get.
spencwad is offline   Reply With Quote
Old 10-10-2009, 08:12 AM   #2
Xemeth
Vehicle: 2002 GT
Send a message via AIM to Xemeth
Well, if you screwed the threads up bad enough on the inside, you're looking at a new crankshaft.
How did you screw the threads up? You should have realized you cross threaded them pretty quickly.
__________________
2002 GT, H/C/I 4v.
Xemeth is offline   Reply With Quote
Old 10-10-2009, 10:39 PM   #3
Bullitt2theHead
Vehicle: 2001 Ford Mustang BULLITT
Send a message via AIM to Bullitt2theHead
With a steel crankshaft, and a mechanically skilled person, it shouldnt be too much of a problem tapping new threads in. I dont know the dimensions of the steeda pulley but if its close in thickness (amount of crank bolt it takes up) to the stocker, just go to the ford dealership and get a new one.
__________________
Just a slow, 8 year old 100,000 mile mustang.
Mods-K&N, Offroad H-pipe, "Bored Mechanic Special" Cherrybomb exhaust, 4.10's, Centerforce clutch, Sniper Tuned!
Bullitt2theHead is offline   Reply With Quote
2010, 302, 40, 50, bolt, bolts, camshaft, crank, crankshaft, dimensions, ford, mustang, pulley, shaft, size
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
