Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2009, 02:12 PM   #21
ShadowDrake
Send a message via AIM to ShadowDrake
Quote:
Originally Posted by trickdriller View Post
Ok, so to bleed the brakes, I put that little hose on there to direct the fluid and open the valve. Then once it's done, close it, pump the brakes 'till it's too stiff to pump anymore, get out and bleed the valve again. Repeat until no fluid comes out?
That's what I remember. Is that right?
More or less.
Have someone hold the brake pedal as hard as they can... open the bleeder a little, close it up before their foot hits the floor if at all possible... just be sure they HOLD THE PEDAL if it does go all the way to the floor. Close the bleeder, allow them to release it and press a few times.
Check the reservoir to be sure you're not going to pull air in - and repeat until no more bubbles are coming out of the line. I generally do it till I get clean fluid out... but as I said, I'm abusive towards my brakes and like to keep fresh fluid at the ends.
__________________
2004 Black Premium GT (5spd)
-Procharger P-1SC intercooled
-Moates.net Quarterhorse
-Tuned with Binary Editor
MY PICTURE THREAD:
http://www.mustangforums.com/forum/s...d.php?t=497078
ShadowDrake is offline   Reply With Quote
Old 10-15-2009, 03:35 PM   #22
cliffyk
cliffyk's Avatar
Here's the procedure from the '03 service manual...
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 10-15-2009, 03:53 PM   #23
trickdriller
Vehicle: 2003 GT
Send a message via AIM to trickdriller
Quote:
Originally Posted by cliffyk View Post
Well that helps Easy enough. Thanks.
__________________
03 Sonic Blue GT
Quote:
Originally Posted by my77stang View Post
and i think at the cutoff date for nominees he was only in office like 2 weeks.
epic uber superduper over-the-top fail.
trickdriller is offline   Reply With Quote
2000, 2001, 2003, blee, brakes, changed, gm, gt, hydroboost, motor, mustang, rotors, soft, spongy, spoongy, vehicle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
