Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-14-2009, 03:20 PM   #1
medrick
2001 Ford Mustang
medrick's Avatar
Vehicle: 01 GT
Default running lean under load
My car is running really lean if i get into it. I can watch my wideband go from mid 14's to pegged at 19.9 and it sounds like its cutting out. It also goes really rich when i let off the throttle all the way down to 10.0. What could cause this? It's an 01 GT
oh and i checked all my cop's and injectors at idle by unplugging them each 1 at a time.
__________________
13.48 on slicks
13.84 on street tires
268RWHP 300 RWTQ
http://www.gearjammersfa.com/
http://www.myspace.com/aaronmedrick
http://www.cardomain.com/ride/3048054
medrick is offline   Reply With Quote
Old 10-14-2009, 04:26 PM   #2
cliffyk
cliffyk's Avatar
Need more details, what are your mods, what did you change recently?
I ask that because obviously you didn't turn 268/300 on a 19.9:1 AFR...
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 10-14-2009, 05:48 PM   #3
medrick
2001 Ford Mustang
medrick's Avatar
Vehicle: 01 GT
havnt done anything recently except mess around in the fuel tank cause i had a filler neck gasket break off inside.
mods are:
long tubes and off road mid pipe
sct livewire with can tune
24lb injectors and maf from a 98 cobra (livewire has an option for the 24's)
75mm throttle body and plenum
accel cop's
ngk iridiums
__________________
13.48 on slicks
268RWHP 300 RWTQ
Old 10-14-2009, 07:06 PM   #4
Frostbitten
check fuel pressure and look for vaccum leaks
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is online now   Reply With Quote
Old 10-14-2009, 09:49 PM   #5
Bullitt2theHead
Vehicle: 2001 Ford Mustang BULLITT
Send a message via AIM to Bullitt2theHead
+1 on checking fuel pressure. However, check it with a mechanical gauge under WOT going down the road and compare it to what the pcm is reading.
Also, just curious, when was the last time you changed your fuel filter? Thats usually the first thing I do before even attempting to diagnose a fuel issue.
__________________
Just a slow, 8 year old 100,000 mile mustang.
Mods-K&N, Offroad H-pipe, "Bored Mechanic Special" Cherrybomb exhaust, 4.10's, Centerforce clutch, Sniper Tuned!
Bullitt2theHead is offline   Reply With Quote
Old 10-14-2009, 11:09 PM   #6
cliffyk
cliffyk's Avatar
Quote:
mods are:
accel cop's
ngk iridiums
How confident are you in the WB O2 system? My vote is that it's packing you full of crap--if you are really running 19.9:1 at WOT you'd be needing an engine after the 1st dyno pull...
Mix and match injectors and MAFs are a recipe for problems--did the Livewire let you select the '98 Cobra MAF too?
__________________
-cliff knight-
My Mustang
Old 10-15-2009, 12:45 AM   #7
medrick
2001 Ford Mustang
medrick's Avatar
Vehicle: 01 GT
recently on the fuel filter. would pulling out one of my o2 sensors (one of the 2nd set that are turned off with the programmer) cause any problems? I wouldnt think so but just trying to figure it out. how would i check fuel pressure? where do I tap in? as far as i know the wideband is accurate.
__________________
13.48 on slicks
268RWHP 300 RWTQ
Old 10-15-2009, 10:08 AM   #8
jgorm
You can't change the maf without getting a retune. that is your problem. See here for more info.
http://www.tricktuners.com/forums/showthread.php?t=110
Quote:
Actually you'd probably be fine. The car won't normally run above about 18:1 due to spark blow out. If you are really seeing 20:1 at WOT your wideband sensor is shot, or you have butchered the free air "calibration" if you have that type of WO2.
__________________
Trick Tuners Forums
jgorm is offline   Reply With Quote
Old 10-15-2009, 11:25 AM   #9
cliffyk
cliffyk's Avatar
Why would an excessively lean mix cause the spark to "blow out"? I agree that at 20:1 it probably wouldn't light up, however the plug will still spark.
My point was that along the way from 14.7:1 to 19.9:1, at WOT, there would be some bad things happening.
I agree 110%, the AFR cannot actually be 19.9:1 at WOT and the engine still be running, let alone producing any power...
__________________
-cliff knight-
My Mustang
Old 10-15-2009, 02:05 PM   #10
jgorm
Well, maybe blow out is the wrong term, but a lean mixture can require a higher voltage to fire the plug, as well as the increased chance the flame front will die out.
__________________
Trick Tuners Forums
0304, 06, 50, car, change, cobra, dyno, gas, gt, intake, lean, mustang, noise, plenum, running, shows, type, underload
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
