Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2009, 07:45 PM   #1
cisurfer
Default urethane motor mounts, car shakes...
i bought the motor mounts off merican muscle and put them in today, they have 4 bolts that attach the two steel plates and inbetween them is the urethane bushing, i tightened these down all the way not knowing what else they are set at...no between 1krpms and 1500 rpms the car shakes alot...did i end up making them a solid motor mount by tightening the plates together?
__________________
cisurfer is offline   Reply With Quote
Old 10-15-2009, 08:32 PM   #2
Frostbitten
there should be a gap between the top plate and the bottom plate so the urethane can flex and absorb vibration
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Old 10-15-2009, 10:30 PM   #3
jrherald420
jrherald420's Avatar
Vehicle: 1968 Mustang 1995 Lincoln Mark 8
Urethane needs some break in time, the trans mount i have for my firebird and the company states break in time is around 300-500 miles. id just give it some time.
__________________
NEW CAR!! 1968 Mustang
1995 Lincoln Mark 8
1998 V6 Firebird
Opinions are like as*holes, and there's alot of as*holes on this site.
jrherald420 is offline   Reply With Quote
Old 10-16-2009, 04:47 AM   #4
cliffyk
cliffyk's Avatar
Then at 30k to 50k miles it will work harden and shatter. Urethane bushings, motor mounts, etc. are great for stiffening things up on race cars and weekend drivers however over the long term they don't hold up well.
That, along with general NVH consideration, is why you see the OEM stuff being made of more resiliant (and also more costly) rubberlike compounds. Using machined or cast urethane would cost a lot less, and because of that alone you can bet they'd use it if they could get away with it...
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 10-16-2009, 10:32 AM   #5
cisurfer
so if i wanna back those bolts out so the two plates arent touching....do i need to rip everything apart again to get them out?
__________________
Old 10-16-2009, 10:37 AM   #6
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
I just went with solid MM.
sxynerd is offline   Reply With Quote
Old 10-16-2009, 12:15 PM   #7
Tim99GT
1999 Ford Mustang
Tim99GT's Avatar
Vehicle: 1999 Mustang GT
How did you like them?? how harsh was the ride?
I need to replace mine and was wondering how the solids were...
__________________
KENNE BELL 2.1L = SOLD
KENNE BELL 2.8H = Waiting to be installed
Aftermarket parts for sale - http://mustangforums.com/forum/new-e...ts-4-sale.html
Tim99GT is online now   Reply With Quote
Old 10-16-2009, 12:24 PM   #8
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Solids feel like Urethane. If you have a stock K member I say 100% get the solids over the Poly. If you have a Tubular K member, there's going to be a little more NVH to consider that could possibly sway your decision. The way I see it, at that point on the mod list the car's isn't really meant to be Cadillac.
With my cams, my car shakes the walls.
Old 10-16-2009, 12:29 PM   #9
Tim99GT
1999 Ford Mustang
Tim99GT's Avatar
LOL^^ Yea, its not a DD. But i do have a PA racing K thats going in the car with cams/ect...
But i dont want it to feel like a top fuel car when sitting at a light either. I might just stick to the urethane mounts and call it a day.
__________________
Old 10-16-2009, 12:33 PM   #10
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Hell, for the price, you might want to consider just trying the solids first. You can always sell them for what you paid for them. I paid 30 shipped from egay. Poly's are $100+. If you don't mind the swap work that is.
1996, 5th, car, engine, gear, gt, motor, mount, mounts, mustang, pics, s197, shakes, shaking, urethane
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
