Not getting enough glue on the plug is one way. I use lots of glue. I was also taught many, many years ago to light the excess glue and let it burn for a couple of seconds. I don't know if it actually makes a stronger bond or not but it can't hurt. The plug I'm running now is in an ultra high performance all-season tire. I like to play a little on the back roads and it has held up to everything I've thrown at it including burn-outs.
Excellent, thanks for the info man. I'll throw a plug in it this weekend.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
+1 on burning the sealing compound. thats what i did on my front tire. i had a wood screw in it so i plugged it. been running on the plug for 500 miles so far no probs
__________________
2001 mustang gt
'95 cobra r wheels. 275 front. 315 rear.
bbk 75mm tb. C&L plenum. new intake manifold.
no mufflers no cats. 10th anny cobra front brakes
1250w infinity sub. 350w kicker amp. pioneer system.
sub frame connectors. aluminum control arms.
pro 5.0 sts. sct tuned
and the best mod of all: 3.73's
Take it to Discount Tire if there is one close to you. They will fix it for free. They use a solid rubber plug through the hole, a rubber patch on the inside with rubber sealer over that. That is the right way to do it, rope plugs will create a tread seperation leading to a blow out.
Man plug that thing. Plugs are not the best thing in the world but they work. I had one in a tire and went 140+ mph. Not the smartest thing I have done, but they work ...
Guys... Seriously. This is like wrong info city.
There is a reason that no shop will plug your tire if the hole is in the sidewall. Plugs do not hold themselves in a tire. Plugs are held in the tire by the cords, not by the glue or the plugs themselves. Without cords, ie in the sidewall of the tire there is nothing to hold the plug in place. Regardless of the fact that some of you may have used a plug before and it worked, it's still extremely dangerous to use a plug in a sidewall.
__________________
Red 1996 GT
PI Swapped
BBK Shorty Headers
Pypes HFC'd X Pipe
Magnaflow Catback
Fender-Well CAI
Hurst Billet Aluminum Shifter
Rear Window Louver
Drilled/Slotted Rotors with High Perf. Pads
Hood Pins!
Sequential Tail Lights
Awful Looking Stock Rims Painted Gun-Metal
I recently had a nail in my tire, pretty close to the sidewall also. I still have the BFG's on my car. The Dealer took it off, patched it, and it is fine. They said since the sidewall is so stiff, it would be fine, and they were right. I have driven it hard since the patch job, and I'm happy to report it is holding well. Good luck!
__________________
08' GT Premium Convertible
Borla Stingers
Navigation
More to come!
Just plug your tire and forget it, do not slime it though b/c it can throw it off balance with that goop inside your tire, not to mention a mess when installing a new set of tires later on down the road
__________________
1996 Mustang GT
o/r x pipe
flowmaster cat back
B&M ripper shifter
I agree that you do not plug a side wall. But as I understood the problem the hole was in the tread a little too close to the side wall for a patch to hold.
__________________
370 rwhp/377 rwtq
Procharger P1SC; BBK 75mm TB/Plenum
BBK LT Headers/catted mid-pipe
Miezere Electric Water Pump
13" Cobra brakes
