Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-24-2009, 03:33 PM   #21
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
A few of you guys are leaving something out of your replies. OP, what's your Compression at? If you're running anything more than stock compression (Like the person running the cobra shortblock with 2v heads, 10.6:1) you should consider Meth injection with the I/C. If you're running lower compression (<9.5:1) then you'll be ok with just the FMIC.
If you don't feel safe running Meth, tune it for water. You wont be able to run as much timing at with meth but you'll always have water and if the pump breaks your tune wont be so aggressive that you're going to detonate. (Well, hopefully you'll notice it's not working first.)
Which Paxton do you have? Novi2k w/ FMIC will put a 10:1 compression engine w/ stock heads and cams at 500rw with 15lbs of boost after the I/C.
sxynerd is offline   Reply With Quote
Old 10-24-2009, 09:22 PM   #22
mynamesbryan
to answer the last couple posts first off i havent touched the axles i have the stock 8.8 ford rear end but i was told i should be fine with that especially since im running an automatic. secondly im keeping the compression realtively the same.. i havent decided yet if i want to pull timing with the meth or just use it as a safety muesure because your right sometimes the pump may fail and then you have detonation..
as far as the stall on the converter goes it was set to 3000 with my old build and tune @360rwhp, with the gain in power with the new build my tuner tells me the stall rises with horsepower gains. if anyone can prove that right or wrong let me know cause i was planning on restalling it to 4000 if it was false
__________________
the fastest get paid the fastest get laid..
mynamesbryan is offline   Reply With Quote
Old 10-24-2009, 09:29 PM   #23
mynamesbryan
Quote:
i have a novi 1k.. planning on upgrading soon depending on my numbers after my tune/dyno
__________________
Old 10-24-2009, 09:52 PM   #24
Hangwire
Hangwire's Avatar
Vehicle: 2003 GT Auto
Quote:
Originally Posted by MU71L4710N View Post
well the cobra eaton is terrible. boost is a measurement of restriction in your intake from the cylinders, 10psi on one car doesnt mean another car will make the same power at 10psi. his car is alot different than a stock cobra with 10psi on the heaton.
op, you mentioned everything but rear end. you changed your axles/lsd out yet?
Oh for real? You learn something new every day!
__________________
Chopped And Screwed
Hangwire is offline   Reply With Quote
46, advances, buy, charlotte, engine, forum, forums, injection, install, meth, methanol, mustang, spray, supercharged, supercharger, timing
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
