Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-23-2009, 06:47 PM   #1
mustang565
Vehicle: 97 mustang GT
Default 97 4.6 fuel delivery problem, help me figure this out.
Well the originall issue I had was the car would drive perfectly fine then randomly wouldnt start. I could drive it for two hours and it would run flalessly then I would turn the car off and it would turn on and run for about 3 seconds then turn off. It would do this for about an hour then turn on and start running normall again. Over the next week the problem would happen more and more often. Every time the car would crank for about 4 seconds then start. I put a fuel pressure gauge on the motor when it was having this problem and you could clearly see it start up and go to about 30 pounds then you could watch it drop to about 15 while the motor was running then shut off all in about four seconds . So I know it was a fuel issue. I haver checked the inertia switch in the trunk and it was fine so I switched the in tank fuel pump and fuel filter. And it worked, The motor would start up first crank and it ran great. It ran great unfortunatly for about a week. I drove the car a good amount to, but a few days ago I went out to start it and I am having the same problem. I havent been able to check the fuel pressure but Its doing the exact same thing. and the inertia switch is not flipped. What am I missing here any ideas or thoughts on what my next step should be? I was kind of leaning twords CCRM? At first I had the idea that the new fuel pump i had just put in went bad. but the next day it started right up and ran great, then today its wont start, it will run for about 4 seconds then shut off. Im stumped here so again any advice would be greatly apreciated.
mustang565 is offline   Reply With Quote
Old 10-24-2009, 08:33 AM   #2
DR.DIESEL
Vehicle: 01 ford mustange gt
YOU NEED TO HAVE A SCANNER HOOKED UP WHEN THIS IS HAPPENING TO SEE IF THE COMPUTER IS COMMANDING THE FUEL PUMP ON.ALSO SUBSTITUE A KNOWN GOOD RELAY IN THE FUEL PUMP POSITION.YOU COULD ALSO TEST TO SEE IF YOU HAVE 12 VOLTS ON THE POWER SUPPLY PIN ON THE RELAY CONNECTOR IN 2 SPOTS,A GROUND PATH IN THE OTHER AND THE LAST SPOT IS THE FEED TO THE FUEL PUMP.
DR.DIESEL is offline   Reply With Quote
Old 10-24-2009, 11:25 AM   #3
mustang51js
Vehicle: 2002 mustang gt
isnt there 2 fuel pumps on these cars one in the tank and one closer to the motor?
__________________
02 black gt,vortech sc,3.25 pulley swap,air to air intercooler,anderson powerpipe,3.90 motive gears,aluminum drive shaft,75mm tb,75mm trick flow plenum,38lb injectors,lowering springs,cobra rims front 245/45/17 rear315/30/17,summit racing o/r h-pipe,sss terminator cat-back,CHE LCA'S, Ford racing UCA's. 90mm lightning maf and sctx3 tune
mustang51js is offline   Reply With Quote
Old 10-24-2009, 12:15 PM   #4
0949er
Vehicle: 2004 Mustang GT
Quote:
no there is only one fuel pump (that is above the fuel tank)
__________________
MODS:
Comp Cam Stage 2's (XE 270AH)
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
288 wrhp / 310 wrtq (Tune by Pro-Dyno.net)
"Supercharger Turbonator Stage 2"
NEW VIDEOS!!!
In Progress:
Vortech V-1 T-Trim 60% Parts, 0% Install
0949er is offline   Reply With Quote
Old 10-24-2009, 02:52 PM   #5
mustang51js
oh i was thinking fuel filters but i could be wrong on that to,and my fuel pump is in the tank
__________________
Old 10-24-2009, 10:43 PM   #6
5.0 85 GT
i think there is a fuse under the hood ont he driver side for the pump relay or some jazz, try replacing that...your pump could have gone bad tho, i put one in my 88 cougar, it ran great for 1 day, then it died, put a new one in the next day and boom she runs perfect...knock on wood
__________________
Big Snake, Little Bite...Full Bolt-On 97 Cobra, Bored .30 over...Need Kenne Bell
-1986 IROC-Z-SOLD
-1985 GT T-Top-SOLD
-1994 GT-SOLD
-2002 GT-SOLD
-1997 COBRA-LOVE!!
-1988 Mercury Cougar Bostonian, 5.0 60k Mile Peach
-1985 GT-Carb'd Special, Bolt on's and a t-5 n Sunroof!
-1993 Ford F-150 4.9I6 5 Speed-WON'T DIE
5.0 85 GT is offline   Reply With Quote
Old 10-27-2009, 04:16 PM   #7
mustang565
Well I replaced the CCRM and the problem is still occuring. Unfortunatly I do not have a scanner so i cant determine the problem that way
Maybe Im not understanding correctly, I thought the relays are located inside the CCRM? Is there another relay that I could just swap without replacing the whole CCRM? The one thing I havent done is check the power supply going to to the fuel pump, which in order to do so I need to drop the tank and test it right at the fuel pump, incase there is some obstruction in the wire. And yes I'v checked the fuse under the hood.What else could possibly be causing this to happen?? I mean theres the fuel pump, fuel filter, fuse and relay?? what else could casue this problem??
46, 88, delivery, ford, fuel, fuse, hood, im, iroc, mustang, pressue, problem, problems, proper, pum, starting, test
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
