Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-02-2009, 05:01 PM   #1
Wolfe008
Default Failed Smog (HC ppm emissions)
I barely failed in the category of HC, low speed. I got 58 and the max allowed is 51...at high speeds I passed getting 35, and the max is 35.
What cheap steps can I take hopefully correct this problem.
I've been told
I heavier oil, go with a straight oil, 30 or 40 weight (not blend)
go to pep boys and get some additive thing that lowers the HC (not even sure what this is, neither was the mechanic who told me)
Fuel injector cleaner (the stuff u add to the gas tank, similar to above ^ )
spark plugs
suggestions please...
__________________
99 Cobra, FRPP 4.10 Gears, Steeda Underdrive Pullys, Steeda Tri-Ax Short Throw Shifter, FRPP Headers, Steeda X-Pipe & Exhaust, MAC cold air Intake, Chip, Ram Powergrip Cluth, MM Road & Track Box Suspension Kit, 9x18 10x18- 295/35/18 BFGs g-force T/A KDW2
Wolfe008 is offline   Reply With Quote
Old 11-02-2009, 05:52 PM   #2
99 GT vert
99 GT vert's Avatar
Vehicle: 1999, Ford, Mustang
Send a message via AIM to 99 GT vert
the only suggestion i have is to move to a state that doesn't have emissions testing
__________________
99 GT vert is online now   Reply With Quote
Old 11-02-2009, 06:51 PM   #3
0949er
Vehicle: 2004 Mustang GT
I wonder if you could get your car tuned down real low just for the test? But even then, you will have to re-tune it again, and depending on if you have a tuner or have somebody do it for you, that could get pretty pricey.
do you have cats? If not, there probably isn't really much you can do except get it tested w/ cats on. (which would mean more then likely a new mid pipe)
__________________
MODS:
Comp Cam Stage 2's (XE 270AH)
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
288 wrhp / 310 wrtq (Tune by Pro-Dyno.net)
"Supercharger Turbonator Stage 2"
NEW VIDEOS!!!
In Progress:
Vortech V-1 T-Trim 60% Parts, 0% Install
0949er is offline   Reply With Quote
Old 11-02-2009, 11:35 PM   #4
Frostbitten
you just need to run the car hard before you take it to get tested. it will burn out your cats and lower the hc's. the stuff carried at most parts stores is called "Guaranteed to Pass". That is meant for cars that are having problems and cant pass. If your car is running good it shouldnt need it. I dont think different oil will make a difference. I would stick with the recommended weight. A good thing to try would be something that cleans the valves like a good fuel injector cleaner. I always use lucas brand. If you really want to get serious you could take the intake off and clean all the accumulated oil out of it
__________________
03 GT 5spd
Hellion 62mm w/Flowmaster cat back, DSS ProMod shortblock, ported heads, manley nextek valvesprings, spec stage 3, billet flywheel, UPR kmember with MMR A arms and MMR coilovers, dual 03/04 cobra pumps w/BAP, SCT BA2800, siemens 60lb injectors, sct x3 with speedy dyno tune......532whp/630wtq
Frostbitten is offline   Reply With Quote
Old 11-03-2009, 12:55 AM   #5
Wolfe008
Quote:
I think "guaranteed to pass" and the fuel injector clearer are both administered the same way, pour in the gas tank...so which one would be better? or should I do the injecter cleaner, and on the 2nd tank of gas right before the test do the guaranteed to pass flued...
Thanks
__________________
Old 11-03-2009, 12:22 PM   #6
smitty2919
Vehicle: 2004 GT 40th Ann.
like stated above, drive the care for a bit before going to get it tested....up to operating temp if you didnt before. seems like you are on the threshold for pass/fail
that combined with the "guarentee to pass" stuff may work
smitty2919 is offline   Reply With Quote
Old 11-03-2009, 01:27 PM   #7
H0SS302
2001 Ford Mustang
My Garage
Vehicle: '01 GT Vert;
Send a message via AIM to H0SS302
the cheapest way would be to put the stock midpipe back on.. ull pass with flying colors and it only takes 30 mins to swap it out
__________________
Corner Carving > All
H0SS302 is offline   Reply With Quote
Old 11-03-2009, 02:00 PM   #8
Derf00
HC is hydrocarbons usually caused by blow-by (oil) in the exhaust. Best solution is to decarbonize your intake and clean out your PCV tube. Decarbonization can be done by you. Get some Berrymans throttle body and intake cleaner, disconnect the inlet tube from teh intake where it connects to the intake manifold. Start her up (preferabbly have someone to keep the engine running as it may want to stall). and spray away until the can is empty.
This cleans out all of the carbon, oil film, and sludge that builds up in the intake. Run it around no higher than medium throttle until you take it to get smogged. WOT tends to cause blowby because of the added pressure in the PCV system.
Derf00 is offline   Reply With Quote
Old 11-03-2009, 02:41 PM   #9
Repzard
Repzard's Avatar
Vehicle: 99 Ford Mustang GT
Maybe run some seafoam through your vaccume line on brake booster.
That will clean out any carbon.
Just a idea.
__________________
My cars owned
But really happy to own my 1st Ford
06 Cobalt SS\SC - Gone !! What a POS
93 Corvette 40th - Great Car( Stock )
99 Mustang GT- Upgrades As Followed : Flowmasters 40 , After market H pipe w/Cats , gears 4:10s , Engine is stock but many upgrades to come
New Mods, Tinted rear tail lights,Tinted windows 35%,k&n cai
Quote: If you see my Mustang or Corvette on a trailers.
Call the Police....Its been stolen !!!!
Repzard is offline   Reply With Quote
Old 11-03-2009, 03:02 PM   #10
Derf00
That would work too
2005, codes, emission, emissions, fail, failed, gt, hc, hcppm, high, low, mustang, ppm, ppms, smog, speed
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
