Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2009, 04:40 PM   #1
preston145
preston145's Avatar
Vehicle: 1998, ford, mustang gt
Default help with wiring for msd window switch!!!
ok guys so i just purchased a MSD window switch pn 8956. its the one you use the pills for. so right now i have my nitrous all wired up and it sprays with the wot switch. i want to wire up this msd window switch as well for safety measures. question is i have looked up and researched which wires go where but yet i dont know where i would hook them up on my already wired system.
im guessing the red wire goes to the switch 12 v source and ill tap into the line my wot switch goes to,
black connects to a ground. i guess ill connect it to any good ground on the chasssis
yellow connects to the ground on the device i plan to activate.. so do i connect this to my wot switch negative side or to the nitrous solenoid or what????
white goes to the rpm input wire. yet i have two coil packs and spark plugs everywhere. which wire would i tap into for a rpm signal wire for the switch?
my car is a 98 gt with the full pi swap. thanks alot guys hope yall can help
__________________
Full Pi swap, 87mm maf, 24# injectors,walboro 255, 373's,K & N Fipk, sct chip, steeda k-member, udp, tokikos 5 way F/R lots of suspension upgrades
preston145 is offline   Reply With Quote
Old 11-06-2009, 06:07 PM   #2
red347
http://www.msdpowersports.com/pdf/frm24819_pn8956.pdf
red347 is offline   Reply With Quote
ford, switch, window, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
