last night i was slamming gears and my tob exploded. also the retainer that the tob rides on(is that what its called?) broke in the middle. the tob was a new oem ford unit and the trans is a tko 500 with 26 spline input shaft. there is also trans fluid leaking from the input shaft. has anyone else done this? i need to get the best tob i can get and retainer the cheapest i can get them, where would i buy them? also i will take of the clutch(spec stage 1) and inspect it. i'm thinking about replacing just the disk with maybe a centerforce like on here: http://dagostinoracing.com/index.php...93_17825_17826
anyone know where else i can get just a clutch disc? would i be fine with a new disc and re-surfacing the flywheel?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Bullitt #15
13.620@102.9 2.065 60' best n/a time
103.9 best trap speed n/a
vortech non intercooled and some sweet stuff, lost the dyno sheet :O 370ish whp 370ish wtq
13.134@110.31 spinning
70mm turbo in the near future
well i'm sure something else caused it to fail but i wouldn't worry in your case. i see you have long tubes with the stock tranny? its possible to get the tranny out without taking the lts off but putting it back on is a different story!
when my tob failed i just heard chunks of metal flying around in my bellhousing. it makes me feel better having a sfi rated bellhousing now...
__________________
Bullitt #15
i'll call promotion powertrain monday to see if they have the retainer. the t5 retainer is the same right?
__________________
Bullitt #15
__________________
Bullitt #15
i found the ford oem tob for around 50 shipped on dagostinoracing, thats cheaper than jegs and summit. how much are they from the dealer?
__________________
Bullitt #15
When I blew up my TOB (and yes it can happen)... I just took the opportunity to replace everything from my input shaft, to my clutch and flywheel.
Mine was actually covered under warranty somehow, and the dealer said they'd replace my flywheel for free with a stock one because it was dead and the whole job was covered... So you may want to get a look @ that flywheel see if there was any damage done to it.
yes i definitely will. with chunks flying around in there who knows what got fugged up. does anyone know what warranty is on a tko 500 and a spec clutch, i've had them for 2 years..
__________________
Bullitt #15
The pic of the retainer wouldnt open for me but im gonna guess your talking about the clutch fork?
__________________
Motor by bumpperformance.com:
npi block compression 10.6:1
stage I ported pi heads/stage I comp cams/PI intake/24# injectors
Cobra oil pump/High output water pump/Mac UD Pullies
Exhaust/Intake:
MAC LT headers/O/r H-pipe/American Thunder catback
p&p tb-pl/C&L cai
Drivetrain:
King Cobra Clutch/Motive 4.10's/Steeda Pro 5.0
Suspension/Tires:
Black cobra r 275/40
Conservative 87/89 Dyno
290rwhp 320rwtq
Next up:
Upr+lwr Control arms & subframe connectors
