Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 04-06-2006, 05:29 PM   #71
d3mon
Default RE: TECH: Manual transmissions, T45, T5, 3650, T-56 ETC
Blew up My tranny so I’ve been leaning the hard way
79-93=T5
96-early 2001=T45
Late2001-03(including cobra 99 till 02, Bullit and Mach 1=3650
Cobra 03-04=T56
between 98 and 99 the T-45 Had some changes they are slightly different and the speed sensor is different 96-98=mechanic speed sensor
99-early 2001=electronic speed sensor
So pretty much the 3650 and the 99-early 01 T-45 are direct swap, 3650.
T-45 99-early 01 will fit in a 96-98 but you will need some mods to make your speedometer work
the T56 (from a cobra) will fit in a 4.6l but you will need a shorter drive shaft and a 10 spline input shaft, if you want to adapt a T56 from a camaro, corvette or other you will need bellhousing, intermediate plate, clutch fork, 10 spline input shaft, and cross member off of an 03-04 Cobra T-56, my two cents
__________________
2K Silvert
d3mon is offline   Reply With Quote
Old 04-06-2006, 05:48 PM   #72
n/a_threat
The gears in a Tremec cannot be replaced from another model. example: gears from a T56 will not work in a 3650. I asked TTC because I was curious about changing my 3650 gear 1 to a T56 gear 1 and they said it won't work.
However, a 3650 can be replaced by a T56 w/ a slightly shorter drive shaft. (one of my projects way down the road.)
__________________
welcome to the fold
n/a_threat is offline   Reply With Quote
Old 05-20-2006, 04:44 AM   #73
Stang Bamf
Default RE: New Mustang Owner ? about Trans
T-3650's are just about as ****ty as the T-45's, my second gear syncro went out, got that a couple other **** fixed in it, still clashes going into second, brand new throw out bearing, now its making noise's 4 hours after it was put in (a mechanic at a dealership who did it is still wondering why the 2nd is all ****ed up bc he thinks it may be the forks, but thought they looked fine when it was apart)
Stang Bamf is offline   Reply With Quote
Old 05-20-2006, 05:50 AM   #74
racer02GTstang
Send a message via AIM to racer02GTstang
i have a tremec 3650 in my car as of this monment but i have a tko500 (pro 750) from mustangmodularracing.com ..... the tranny is built and for the swap to a tko, you will need a new bellhousing, clutch, tranny, and might as well get a new flywheel since you are starring right at it when the clutch is removed. the capacity of my tranny is 750hp and 750 torque... i blew the syncro's out of 3rd gear of my 3650 so i decided to beef up the drive liine with a TKO in there....
__________________
2002 GT ragtop 5-spd
HP stage 2 twin turbo kit
forged shortblock from MMR
VT stage 3 blower cams
stage 3 ported heads w/ oversized valves
built TKO500
P-51
+ alot more
693rwhp 608 toque w/ a slipping clutch and 18psi. on pump gas
racer02GTstang is offline   Reply With Quote
Old 06-17-2006, 03:35 PM   #75
ginasstang
Default RE: Manual transmissions, T45
anyone know of a Ford recall for t-45 transmissions, something to do with the sychronizers??
thanks
ginasstang is offline   Reply With Quote
Old 06-17-2006, 04:06 PM   #76
monkeydude3
no, just a crappy transmission, i rebuilt mine with new synchros and it shifts smoothly now but is still a piece of crap
__________________
2004 Honda Civic ~ Daily Driver
1969 Chevy Impala ~ Project
2003 + Ford Mustang Cobra ~ Coming eventually!
monkeydude3 is offline   Reply With Quote
Old 07-31-2006, 04:10 AM   #77
snowboard22004
Default Transmission Fluid
I bought my 96 gt about 4 months ago, and i dont know if the guy change the transmission fluid ever. Should i flush the fluid??? i have heard that if it hasnt been flushed for a long time that flushing it is just going to make more problems so what should i do?
snowboard22004 is offline   Reply With Quote
Old 07-31-2006, 04:10 AM   #78
snowboard22004
Old 07-31-2006, 05:13 AM   #79
eventer289
Default RE: Transmission Fluid
I have a 2002 GT with the TR3650. I bought it in January of 2006. Is there anyway to find out if the 2nd gear synchro was "beefed" up under the warranty? It was bought from a used car dealer and I do not have any of the maintenance records so I do not know if this was done or not.
__________________
2002 Mustang GT
Car Domain-- http://www.cardomain.com/ride/2547005
eventer289 is offline   Reply With Quote
Old 07-31-2006, 05:24 AM   #80
ShadowDrake
Send a message via AIM to ShadowDrake
Quote:
ORIGINAL: eventer289
It's doubtful that it was done. I know mine isn't, and it's starting to get REAL weak... in normal driving it'll just grind, clutch is on the floor and I'm shifting from about 3200 RPM and it'll just grind instead of going in, like there's no synchronizer there at all... does this about 1/60 shifts from 1-2, but it's becoming more frequent, it's rather embarassing. 2-3 shift is real strong and I've grinded it all but once or twice, I seem to grind the 1-2 shift all the time though, even with the clutch to the floor and light driving.
If you're not having problems with it by this time, the TSB will not be an issue for you.
__________________
2004 Black Premium GT (5spd)
-Procharger P-1SC intercooled
-Moates.net Quarterhorse
-Tuned with Binary Editor
MY PICTURE THREAD:
http://www.mustangforums.com/forum/s...d.php?t=497078
ShadowDrake is offline   Reply With Quote
01, 2004, clutch, manual, mustang, rebuild, replace, sale, service, speed, t45, t56, transmision, transmission, transmissions
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
