Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-25-2005, 04:39 PM   #1
mustang dan
Default 4.6 stroker kit?
does anyone make one?
__________________
http://www.d1musiconline.com/dweb.html
The next big thing...
mustang dan is offline   Reply With Quote
Old 08-25-2005, 04:50 PM   #2
Acer2428
Armed Moderator
Acer2428's Avatar
Vehicle: F-250 7.3L Powerstroke
Default RE: 4.6 stroker kit?
Most of the major rotating assembly companies do.
Try CHP.
5.1L is the biggest right now I believe, but most are 5.0.
__________________
Quote:
If god wanted you to hit your target on the first try, he wouldn't have invented the semi-automatic.
Acer2428 is offline   Reply With Quote
Old 08-25-2005, 09:26 PM   #3
David_K
i have a friend with a 5.5L 99 cobra. used a 5.1 crank and bored it like .60 over or something. a set of pistons cost him 1200 dollas
__________________
David_K is offline   Reply With Quote
Old 08-27-2005, 02:34 AM   #4
02StanGT
These guys make one also.
__________________
Pour me another, you're still ugly.
[sm=icon_guiness.gif]
'99 Mountaineer 5.0 AWD - HID, MAC CAI, Sniper Tuning, PMAS 75mm MAF
'97 Camaro RS - HID, HPTuner, Bolt-ons...
02StanGT is offline   Reply With Quote
Old 08-27-2005, 03:35 PM   #5
2000GT4.6
Quote:
ORIGINAL: David_K
I think he is bull****ting you. If ya do a 60 over bore in a 4.6L block, it would probably glow if you dropped a light into the cyl.
Besides that cyl bore adds very little displacement. The largest kit i have seen with a stock block was a 5.1L.
__________________
2000GT4.6 is offline   Reply With Quote
Old 08-27-2005, 07:47 PM   #6
David_K
Quote:
ORIGINAL: 2000GT4.6
Quote:
ORIGINAL: David_K
nope its sleeved. ask code. i helped this guy put it together
__________________
Old 08-28-2005, 01:54 AM   #7
S9V9T
Quote:
ORIGINAL: David_K
Quote:
ORIGINAL: 2000GT4.6
Quote:
ORIGINAL: David_K
David_K is talking about my motor. It is like a 5.3L or something. The bore on this motor is .154 over not .60 like David_K said... [sm=chairshot.gif]
the bore is 3.704 and the stroke is a 3.755... piston size is 3.695... rod length is 5.880. Put that all together and you will come up to a 324 cid. Here is the formula to come up with any cid:
Formula to Calculate the CID (Cubic Inch Displacement) of an engine:
R² × Pi × H × number of cylinders = CID (Cubic Inch Displacement)
In other words;
Radius of the bore squared × 3.14 × Stroke × number of cylinders = CID
For my engine with a 3.704" bore and a 3.755" stroke, the formula reads:
1.852² × 3.14 × 3.755" × 8 = 323.52772 CID = 324 CID
In other words;
1.852² (The radius of a 3.704" bore [1.852"] squared [multiplied by itself, or 1.852 × 1.852] × 3.14 (Pi = 3.14) × 3.755 (3.755" stroke) × 8 (The number of cylinders in this engine) = 323.52772 CID
This formula will work with any engine. For example, the Oldsmobile 350 V8, which has a bore of 4.057" and a stroke of 3.385" would be;
2.0285² × 3.14 × 3.385 x 8 = 349.88742333922 CID
A Ford 351 with a bore of 4" and a stroke of 3.5" would be;
2² × 3.14 × 3.5 × 8 = 351.68 CID
MAKE ANY SENSE?
__________________
<img src="http://i11.photobucket.com/albums/a197/kellylizzious/89450850_m.jpg" alt="Image hosted by Photobucket.com">
S9V9T is offline   Reply With Quote
Old 08-28-2005, 01:58 AM   #8
S9V9T
By the way, you can get the stoker kit from me. But the kit cannot be used with an iron block, it has to be used with an aluminum block.
Kit includes:
Custom forged crank
Eagle rods
JE custom pistons
Cylinder sleeves
__________________
Old 08-28-2005, 02:08 AM   #9
S9V9T
The bored out block (without sleeves):
[IMG]local://upfiles/21375/EA92D048449B410DA566F9BFFB63758E.jpg[/IMG]
[IMG]local://upfiles/21375/A9B06BAFA7714D4B97AB5A98444033FF.jpg[/IMG]
Piston that came out of the motor:
[IMG]local://upfiles/21375/0821B15114C04F95AB485052507392CD.jpg[/IMG]
__________________
Old 08-28-2005, 05:24 PM   #10
David_K
Quote:
ORIGINAL: David_K
i meant lik .060 but i guess its alot bigger than that
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
