Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-19-2006, 07:25 PM   #1
Dark_Horse
Default 96 GT NPI 4.6 to PI 5.4 Swap. (Pic) Starting on 1/21/06 Dark_Horse
ok so the plan is this weekend (1/21/06) i am going to start on my swap, i will take pictures, post them and make notes of whan needs to be changed to make the swap. Here is some pictures of the motor right now. I will update this post when i get new pictures. Hope it goes well.
EDIT:
got bored so i decided to start early, here is what i got so far.
1/19/06
First thing i did was remove the hood, then i put it up on jack stands, drained the oil and coolant.
Removed upper plenum, intake vacuume lines, wiring harness, Coil packs & wires
intake manifold, water pump pulley, alternator, & Electric fan
here is most of the parts that got removed, so far.
1/20/06
side shot of the 4.6 & 5.4 fuel rails
Top
if you look at the red circles (fuel perssure regulators, you will see that the 4.6 can be un bolted and replaced with a after market one, and the 5.4 has a inner snap ring that holdt it inplace. is there after marked fuel press. regulators for this one?)
the green are the quick connect fitings, they are on opposite sides so the fuel lines must be extended to reach. and yes you have to use the 5.4 fuel rail, i put the 4.6 rails on the 5.4 intake and they didn't fit that well... im sure you can make them go on but ill just use the 5.4 rail.
Stock NPI 4.6 intake manifold. has two coolant temp sensors.
5.4 PI intake with aluminum cross over.(only one temp sensor) the green circle on the left was a coolant nipple that went to the heater core. i din't know what it went to so i hacked it off, i milled it down and taped it so i can have both temp sensors in. but later i realized what it was for... the heater core
so i made this... this is going to go on the upper raidator hose and then the nipple will be ran back to the heater core.
1/21/06
a notch had to be cut so the oil pressure sender can be put on.
compairing the two Engines
compairing the two manifolds
these bottom two baffels need to be bent down 1/2 inch
my girl friend wanted me to, lol.
do this befor it goes in un like me so you dont have to pull it out them put it back in.
the passenger exhaust manifold has a casting lump that there is no need for so that had to be cut off for some clearance.
**Do this befor it goes in un like me so you dont have to pull it out them put it back in**
tilting the engine helps get it in/out
Makeing room for the intake so i had to mount the coil on the strut tower
... befor the motor is installed cut this are out, (where it is hammered) the EGR needs room so it is not on the fuel lines. and you also need to add 1 inch to the EGR tube right next to the EGR valve, you can strech/ and bend in the right places to make the 4.6 fit the 5.4. i used the 4.6 because there is no room for the 5.4 egr tube.
Whats that in the scoop?
Now dosn't that look AWSOME!
yes it dose hit on a 3" cowl hood with a SVO scoop. but only on the intake. it can move down
comming close...
oh and if you are going to do this and you have a PI mustang buy the addapter plates they are like $350 and you can use the stock 4.6 intake and notch your the under side of the hood but its not visable form the top. it will make every thing a LOT easyer, belive me. and the runners are shorter on the 4.6 so it will help make a little more hp then the 5.4 intake will. the 5.4 intake with loe longer runners will make more low RPM Torgue and less High RPM HP the 4.6 intake will do visa versa.( i would recommend the 4.6 with addapters)
1/23/06
Exhaust
ok so to make the exhauset fit... i cut the H in half so i can do one side at a time the Driver side fits perfect no modifications needed
Ther passenger side i either need to remove the lower stud to get it on, or can i cut the flange like this and then just bolt it on, im leaning to cutting the flange because it will be easyer then removing the stud if i have to take it out later.
[IMG]http://memimage.cardomain.net/member_images/12/web/456000-456999/456787_481_full.jpg[/image
__________________
98 Camaro M6 LS1 (Headers, Lid, SLP LM1, Ported TB 13.21@108)
03 Evo VIII(Cams, FMIC, TBE, 12.8@106) SOLD
00' 5.4 powered 96 GT(gave to little Bro)
Dark_Horse is offline   Reply With Quote
Old 01-19-2006, 08:45 PM   #2
JonBeast
Moderator
Send a message via AIM to JonBeast
Default RE: 96 GT NPI 4.6 to PI 5.4 Swap. (Pic) Starting on 1/21/06 Dark_Horse
So your finally droppin it in?
[sm=icon_rock.gif]
__________________
JonBeast is offline   Reply With Quote
Old 01-19-2006, 08:55 PM   #3
Fallstar01
Send a message via AIM to Fallstar01
Good luck. Hopefully everything will bolt right up. In any case, it'll be worth the work for the sound of the exhaust and the cool-factor.
__________________
'02 GT vert - white/tan - Supercharged.
Up Coming Mustang Parts: extra idler pulley around SC, front heat exchanger
Fallstar01 is offline   Reply With Quote
Old 01-20-2006, 12:10 AM   #4
M1ke
what year and model does that motor come out of? i know some f150s have it but its kinda different or somethin idk
__________________
Bassani Headers:Bassani Catted X:Borla Stingers:K&N FIPK2:MGW:Accufab 75mm:C&L plenum
ZEX 75 shot
dyno vid
M1ke is offline   Reply With Quote
Old 01-20-2006, 12:18 AM   #5
gt96stang
I hope it goes smoothly for you and you get that thing up and running.
gt96stang is offline   Reply With Quote
Old 01-20-2006, 03:52 AM   #6
xx9gt6xx
Send a message via AIM to xx9gt6xx
Quote:
ORIGINAL: gt96stang
Yup! Good luck Derek, keep us posted
__________________
..Modded 1996 Ford Mustang GT.. SOLD!!
..Modded 2001 Ford Mustang SVT Cobra.. SOLD!!
Now..
..Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition..
xx9gt6xx is offline   Reply With Quote
Old 01-20-2006, 05:54 AM   #7
Dark_Horse
added new pictures...
__________________
Old 01-20-2006, 05:57 AM   #8
Dark_Horse
Quote:
M1ke
the 5.4 was a option motor i think, it comes in any modular Truck,i would only get a 2000 or newer because some of the '99s were both PI and NPI. they are found in F-150, E-150, F-250s and other ones im not sure
__________________
Old 01-20-2006, 09:39 AM   #9
nanaki
Retired MF Moderator
how long do you expect this to take?
__________________
2004 Mustang GT - SOLD!
2009 Nissan Altima Coupe 3.5 - stock
2007 Pontiac Solstice GXP - GMPP reflash
2007 Corvette - Boltons, Vortech, etc
nanaki is offline   Reply With Quote
Old 01-20-2006, 01:00 PM   #10
Dsmfighter
Send a message via AIM to Dsmfighter
Hell yeah dude... i cant wait to see how this goes... keep us posted!! How much power will that be throwing down??
__________________
-1998 Gt droptop-
Vortech S-trim @ 9psi, PI swapped, bunch of bolt on's with d/r's
12.42@113mph, 1.6 60' on a slipping clutch!
Dsmfighter is offline   Reply With Quote
1997, 2003, 46, 54, dose, e150, fit, gt, intake, manifold, mustang, npi, pi, power, swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
