T3650 to T45 Swap
Old 03-08-2006, 11:34 PM
MichelleBeMyGT
MichelleBeMyGT's Avatar
Default RE: T3650 to T45 Swap
I already have the transmission, there is no taking it back... will the clutch i have now work? and what else do i need?
once it breaks... ill get a TKO... but i'm stuck with it for now
MichelleBeMyGT is offline
Old 03-09-2006, 12:12 AM
Dark_Horse
Dark_Horse's Avatar
MichelleBeMyGT
its not the trany that decids the clutch that is needed its the flywheel. my flywheel that i got for my 5.4 accepts either a 10.5" or 11" so you should be fine the only problem i can think is if the splines are diffrent. and for that just look up a clutch and if it fits from 99-04 then you should be fine.
Dark_Horse is offline
Old 03-09-2006, 12:14 AM
Dark_Horse
Dark_Horse's Avatar
oh and why not just sell it and buy a TKO now and do the swap once? its not fun droping a trany.you have to do the mid pipe the cross support under the trany and the tranymount crossover.
Old 03-09-2006, 10:16 AM
MichelleBeMyGT
We have a lift at the house.... All the correct tools... The tranny install does not take very long at all. We put a TKO in my friends 99' Cobra and it was a quick install.
Hopefully the splines on the T45 are the same as the T3650 so i can use my same clutch.
Thanks
Old 03-09-2006, 11:02 AM
amoosenamedhank
amoosenamedhank's Avatar
A stock flywheel on a car with a 3650 is an 11 inch set up and will not be drilled for a 10.5inch cluch. I also would recomend never to power shift that t-45 or you'll be taking it right back out.
amoosenamedhank is offline
Old 03-09-2006, 11:54 AM
black01gt
black01gt's Avatar
TR-3650 IS way stronger then the T45's Thats why ford went with it. Go find a T56 lol
black01gt is offline
Old 03-15-2010, 05:48 PM
firemedix911
firemedix911's Avatar
I believe the only thing you need is a new shifter for it to fit your car. At least that's what I was told by a trany shop. BemyGt I'm trying to PM but I'm not able to. How can we get in contact. I might need a t-45.
firemedix911 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: T3650 to T45 Swap
