T3650 to T45 Swap
Old 03-08-2006, 06:42 PM
MichelleBeMyGT
MichelleBeMyGT's Avatar
Default T3650 to T45 Swap
I currently have the Tremec 3650 transmission. I bought a built T45 that is much stronger than the T3650. I would like to install the transmission. The t45 came out of a 2000 Mustang GT.
I have heard the clutch in the 99-01.5 mustangs have 10.5" clutches.... Will my clutch work on this transmission since it is an 11" clutch?
I also heard the only other difference is the backup light plug....
Any input wanted...
Thanks
MichelleBeMyGT is offline
Old 03-08-2006, 06:43 PM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: T3650 to T45 Swap
Why are you wanting to swap? I always thought the 3650 is a better tranny????
code3GT is offline
Old 03-08-2006, 06:45 PM
MichelleBeMyGT
Well, my t3650 has major synchronizer problems... It needs to be rebuilt, etc. I was offered a beefed up T45 so i purchased it. It was a whole lot better than the t3650 becuase it could handle more torque....and it doesn't have synchronizer problems as the t3650s are known for.
Old 03-08-2006, 06:49 PM
Zoie_daGT
Zoie_daGT's Avatar
you MAY have a problem because my odometer is mechanical and attaches to the tranny. The newer mustangs have the electrical hookup. I dont know if it would be a problem on yours but you should check that out too.
Zoie_daGT is offline
Old 03-08-2006, 06:51 PM
MichelleBeMyGT
well, the t45 came out of a 2000 so it has the electronic odometer... thanks for saying something, i checked it out
Old 03-08-2006, 07:12 PM
kcp1989
kcp1989's Avatar
the nice thing about the 3650 is you won't completely strip a gear if you miss it once
kcp1989 is offline
Old 03-08-2006, 08:45 PM
nathansmith50
nathansmith50's Avatar
yeah the t46 sucks BAD......even built i'd be careful with it......i would NEVER intentionally put one in my car.....mine is in the shop even as we speak getting a bunch of work......i was going to try to limp through until this sumer and just put a t-56 in but i don't think it would have mad it.
nathansmith50 is offline
Old 03-08-2006, 08:47 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: MichelleBeMyGT
Any input wanted...
Thanks
Boy I really wish you would have listened to me about the T-45. There isn't much they can do to "beef" a 45 except to replace the syncronisers. The gears are weak, and any sncys they put in there are still gonna suck.
If you have ANY opertunity to not do this I would take it. you are NOT gonna like the results. What you are doing is kinda like trying to setup a car for drag racing and swapping the cobra IRS in to replace the 8.8
2000GT4.6 is offline
Old 03-08-2006, 09:47 PM
nathansmith50
^^^^^^listen to that guy......you will be dissapointed with the t-45. it is S H I T!!!!
Old 03-08-2006, 10:41 PM
Monch
Monch's Avatar
is the bolt pattern the same? i didn't think you could go from a 3650 to a t45, but i don't remember anything anymore.
Monch is offline
Quick Reply: T3650 to T45 Swap
