Next Mod
Old 02-23-2004, 03:42 AM
beezy
beezy's Avatar
Default RE: Next Mod
It is pretty damn easy to install, you should be able to do it
beezy is offline
Old 02-23-2004, 03:47 AM
Razor19
Razor19's Avatar
Another question which is better pro 5.0 or Steeda? I know both are great shifters just wondering if you prefered one over the other?
Razor19 is offline
Old 02-23-2004, 03:52 AM
beezy
beezy's Avatar
I have only used the Steeda one. I have heard probally more people say they like the pro5.0 one better and on stangnet alot of them were getting the pro5.0 and the steeda tri-ax handle
beezy is offline
Old 02-23-2004, 11:46 AM
IsMoKeDu
IsMoKeDu's Avatar
The next mod you should do is either a pro 5.0 shifter which you can install yourself or go with a cold air intake. These are pretty basic mods that you should eventually do so why not start now. As for an intake, i would either go with a BBK fenderwell mount or possibly a steeda GT intake. I lean more toward the BBK.
IsMoKeDu is offline
Old 02-23-2004, 02:12 PM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
next Mods: Flows are ok, I wont try to sell you the Spintechs :
1st: 3.73 gears
2nd: Steeda shifter (easy do it your self install-instructions on www.steeda.com)
3rd: 75mm Throttle body- BBK (easy do it your self install)
4th: BBK CAI--not sig gain in performance but it looks good (easy do it your self install)
5th: Nitrous baby!! or Blower
6th: Wheels--upgrade to 18#
7th: Lower it with eibach prokit springs-1.5 " drop.
N2OJunkie is offline
Old 02-23-2004, 03:21 PM
CrazyHorse234
CrazyHorse234's Avatar
I would go with a C&L CAI instead of BBK or STEEDA.
CrazyHorse234 is offline
Old 02-23-2004, 04:48 PM
N2OJunkie
I ♥ Acer
N2OJunkie's Avatar
ORIGINAL: CrazyHorse
it makes no diff man. anyone of those is fine...
Old 02-24-2004, 01:11 AM
beezy
beezy's Avatar
If he is doing the 75mm TB might as well do the plenum with it I have seen it for pretty damn cheap
beezy is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
Quick Reply: Next Mod
