What is double clutching....
what is the correct way to shift when racing. I have heard of terms called double clutching and power shifting but what do they mean and what do you guys reccomend?
Thanks
Thanks
RE: What is double clutching....
power shifting ,,is shifting under full throttle all the time ,,meaning once you let out the clutch in 1st gear,,dont let off the gas bewteen shifts ,,hold your gas to the floor ,,in just pop the clutch threw the gears fast ,,
hotrodman...
how much does this help and how bad is it for your trans, and excuse my ignorance but wont you grind if you are pressing the gas before you put the car in gear?? thanks in advance.
how do you shift???
how do you shift???
A. Double clutching is a pointless/useless thing to try. it slows you down.
B. Double clutching is a 'ricer' term.
C. All of the above are correct[&:]
Power shifting has to be timed perfect too, or you will destroy your tranny. Just try gettin of the throttle a bit, & swithing a gear until you get swift w/the shift[8D]
What would the benefit of double clutching be??? It seems to me like you are just stopping mid shift and doing a pointless step? Is there suppose to be a reason for it?
Back in the day of british sport cars and the like the gea boxes did not contain syncros. Syncros match the tranny speed to the motor speed to give a nice smooth shift. Without them you would get one nastry grind every shift. To stop the grinding on cars with no syncros you need to depress the clutch put it in neutral release th clutch blip throttle depress the clutch shift into the next gear release th clutch. That takes time. It is not nessecary in today's car. Don't even bother trying to do it.
What you should practice is heel-toe. This will help smooth out downshifts when coming to a stop and/or racing. Heel-toeing is when you downshift and under braking you brake with you toes and blip the throttle with you heel just enough to match the revs when you release the clutch. I have difficuly doing that way so what I do is brake with the inside of my foot and roll the outerside of my foot into the throttle to blip it. It will take some practice to do it right everytime. But it eliminates the jerkiness of downshifts and is far more usefull than duble clutching.
ORIGINAL: yellowstang98
hotrodman...
how do you shift???
hotrodman...
how do you shift???
Not saying 'Playboy' is an authority but in the March issue of this year they say this about double clutching for a corner:
Page 45
left foot on clutch
Right foot on brake – so can reach gas pedal
Shift to neutral
Release clutch
While pushing brake pedal roll foot to blip gas so rpm is increased
Match speed of rear wheels to lower gear
Engage clutch
Downshift
Let out clutch
Now we can smoothly apply power while we clip the corner of the apex.
Page 45
left foot on clutch
Shift to neutral
Release clutch
Engage clutch
Downshift
Let out clutch
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
DreadPirateRoberts
09-26-2015 02:11 PM
