belt tensioner- Q - MustangForums.com
Old 03-27-2006, 02:09 AM   #1
mustang_montana
Default belt tensioner- Q
my belt tensioner is stuck, it wont budge but its not damaged at all and the spring still works. i doused it with wd40 and unbolted it from the engine, then put it back on and popped the black lever up and the arm wont budge. i never really messed with it before and dont know if theres a specific way to push the arm back so i can slip my belt on. thanks a lot.
mustang_montana is offline   Reply With Quote
Old 03-27-2006, 02:18 AM   #2
monkeydude3
Default RE: belt tensioner- Q
have you tried moving it both ways?
monkeydude3 is offline   Reply With Quote
Old 03-27-2006, 02:19 AM   #3
mustang_montana
yeah it wont budg, i may have torqued it wrong. its supposed to be 15-22 i believe, but either way it wont budge inside or outside of the car. ill be buying a new one tommorow unless i figure it out. its gonna hold me up otherwise
Old 03-27-2006, 02:22 AM   #4
monkeydude3
and you are sure you are trying to move it at the right spot? You tighten it at the pivot point and there should be a square that fits a 3/8" socket somewher eon it, either that or another bolt that you twist it on
Old 03-27-2006, 02:29 AM   #5
mustang_montana
yeah i tried both ways, tightening the bolt did nothing, would it being the wrong torqe be causing this issue? it seems like the arm is all the way towards the passenger side. im trying to move it towards the drivers side to get the belt around it. so to turn it youre supposed to use the bolt, and the black lever at the top doesnt release it?
Old 03-27-2006, 02:30 AM   #6
monkeydude3
hang on a second, before i start trying to explain, could you get me a picture if it wouldn't be too much trouble? I just need to see what we are talking about. I swapped the water pump (and a belt) with no probs at all on my car so I dunno what's giving you guff
yes over torqueing it could possibly cause problems
George
Old 03-27-2006, 02:46 AM   #7
mustang_montana
i cant get a picture off my car, its dark out and everyones asleep but on your car itll be passenger side with an arm and pulley at the end. 2 bolts on yours and one at the swivel part.
Old 03-27-2006, 02:49 AM   #8
monkeydude3
errr my car is 2 miles away in my sister's garage (she has one, we don't) let me look around real quick see what i can find
George
Old 03-27-2006, 02:53 AM   #9
monkeydude3
it appears as if you are gonna want to crank on it clockwise to move the pulley down and release the tension
Old 03-27-2006, 03:08 AM   #10
crash94
crash94's Avatar
This help?
Pay no attention to the dirt!!
[IMG]local://upfiles/27213/35C2B5707E5E4545AAB484242CAD1A77.jpg[/IMG]
Of course what you need to see is behind the hose. LOL
crash94 is offline   Reply With Quote
High Pitch Whine. Help? FivePointToTheOh 2005-2014 Mustangs 9 09-29-2015 01:53 PM
I did a Video on Measuring for a New Serpentine Belt after a Smog Pump Delete on a 95 autoedit General Tech 0 09-27-2015 07:37 PM
My ac is stuck rafotree 4.6L (1996-2004 Modular) Mustang 5 09-22-2015 04:55 PM
A/C Port locations vargas 4.6L (1996-2004 Modular) Mustang 6 09-19-2015 02:42 PM
alternator. so hot will burn your hand on 2004 3.9 v6 mrmrultimate Texas Regional Chapter 2 09-10-2015 10:43 AM
03, 1996, 2004, 46l, 95, belt, clockwise, cobra, drive, mach, mustang, picture, push, stuck, tensioner
