instake setup
Old 03-16-2004, 03:07 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: instake setup
Know that stock the T/B doesnt really make that much more HP. I went with a 70 MM because I have heard that the 75 really cuts down on the airflow speed, and while it can improve peak HP it decreases HP over other parts of the band. We are only talking like 1 hp or so here.
MM&FF did a dyno, the T/B only gave em an extra 3 RWHP (75mm). If you dont plan on future mods, I would almost save my money for a set of underdrives or something. However 3 hp is still 3 hp, and it makes for a nice clean look and a pretty smooth inlet.
2000GT4.6 is offline
Old 03-16-2004, 10:12 AM
Denis85
Denis85's Avatar
So is this good?
http://www.ssd4u.com/streetsmart_037.htm
The package that is 600$
Denis85 is offline
Old 03-16-2004, 11:12 PM
04ShakinSteed
I ♥ Acer
04ShakinSteed's Avatar
Are you talking the one with the chip??????????
The last ones on that page are something simular to the C&L kit, but I went with C&L...I wanted something dyno tested
04ShakinSteed is offline
Old 03-16-2004, 11:14 PM
04ShakinSteed
I ♥ Acer
ORIGINAL: 2000GT4.6
We're talking the 75mm TB and plenum combo. C&L dynoed and said that is the best combo for THEIR setup. You can do the 70mm, but you won't get every inch of power that you could have
Old 03-16-2004, 11:16 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
With a straight bore you'll never get the power you should have....
jeep45238 is offline
Old 03-17-2004, 02:57 AM
bigbadracer808
bigbadracer808's Avatar
is there much of a difference between the 70mm and 75mm t/b besides the 5mm? i was told that running a 75mm will make my car run lean. is that true? i plan to keep the car na for now but am adding nitrous within the next few months
bigbadracer808 is offline
Old 03-17-2004, 04:52 AM
2000GT4.6
2000GT4.6's Avatar
I dont see how your car could run lean, the MAM should take care of that. I dont think there is much difference between the 70 and 75, but I have heard several reports that say that a 75 increases peak HP, but decreases it over the entire engine band as well.
Remeber we are only talking a few HP here, like 2-3. Probably not even that much. According the the dyno results I saw, changing the stock T/B out for a 75 MM accufab only resulted in like 3rwhp increase. I would guess the 70 cant be that much less. The people that stated the 75 was to big were saying it decreases the airflow velocity. Not sure howmuch bs/truth there is to this, so I just went for the middle road with the 70mm.
At any rate, probably no matter what you do, you wont notice a T/B change seat of the pants style.
Old 03-17-2004, 05:31 AM
GT99GT
GT99GT's Avatar
when you say 75 will add peak HP but not through out the entire band... what exactly do you mean, and what would someone rather go with... 70 or 75, i mean wouldnt 75mm make the car faster than 70mm would regardless
GT99GT is offline
Old 03-18-2004, 12:48 AM
04ShakinSteed
I ♥ Acer
ORIGINAL: GT99GT
No, then your messing with the fuel/air ratio. You can pump more air in without more fuel. Check the C&L site they recommend the 75mm TB with their plenum, they said they wouldn't recommend it without using their plenum. Go with their evidence from the dyno!
Old 03-18-2004, 03:05 PM
Denis85
Denis85's Avatar
my intake setup is going to be, accufab 70mm t/body with plenum,the intake and chip on that webpage i posted before
Denis85 is offline
jwog666
12-27-2021 08:09 PM
Lethaldosage423
10-19-2015 12:12 AM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: instake setup
