Driveline Slack
Driveline Slack
My '02 GT Coupe seems to have a little too much driveline slack.
It has 70k miles and I know that it has recently installed aftermarket clutch, although I'm not sure which. I think it's a King Cobra because the peddle effort is maybe 20% stiffer than stock, not alot, and it seems to grab well, better than I think a stocker would.
Anyway, it seems to have a little too much driveline slack, not dangerously loose but enough to notice.
I've heard of people saying that the driveshaft can become loose or maybe the u-joints.
Any ideas on what could be causing this and any reasonably quick ways to check it?
Thanks,
Vince
Thanks,
Vince
2010 Blue Ball Award Recipient
RE: Driveline Slack
is driveline slack waht causes the car (usually in 3rd 4th and 5th) to chunk or clunk back and forth if youre not high enough in the rpm range and give it too much throttle?
RE: Driveline Slack
ORIGINAL: suzukidragracer
Thanks,
Vince
Thanks,
Vince
RE: Driveline Slack
I don't think so, but my car does do that every once in a while......under 2k rpm and heavy throttle, usually in higher gears.....I know lugging the engine is not good, but it still shouldn't do this!
For that I would suggest and I am going to: check and replace the sparkplugs, and maybe the wires (i think mine are still the stockers!), replace the fuel filter.
BUT, the DRIVELINE SLACK I was refering to occurs when you are on and off the throttle and the car bucks. You can clearly feel it through the clutch and gas peddles as slack somewhere in the transmission/driveshaft/u-joints/rearend.
Vince
Maybe it's just this crappy TR3650.......
Vince
RE: Driveline Slack
I just have driven alot of manual transmission cars and this one seems to have too much play in the driveline.
I'm guessing it is either a loose driveshaft or u-joints......maybe a loose transmission mount (seems if it were a broken one I should be able to tell that something is WRONG, not just out of adjustment)
Or like I said, just the TR3650 has high tolerances and is loosey goosey.....
Vince
Vince
RE: Driveline Slack
ORIGINAL: 72MachOne99GT
RE: Driveline Slack
Vince
Vince
RE: Driveline Slack
only difference I notice between the two is the 3650's shift gates are much much closer together
Thanks and I will check my driveshaft and tranny mounts!
Vince
RE: Driveline Slack
Really? That is interesting to know.
Vince
Cool let me know how it goes, if u still have problems let me know and I will try and think of anything else that it could possible be.
Vince
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
