HOW TO: CHANGING SPARK PLUGS 99-04 - Page 3 - MustangForums.com
Old 10-08-2015, 01:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Old 08-07-2012, 12:20 PM   #21
kingrukus
What should I gap these plugs at?
kingrukus is offline   Reply With Quote
Old 08-07-2012, 12:20 PM   #22
kingrukus
They are the oem Motorcraft SP-493 plugs - I was hoping they would be pre-gapped.
Old 08-07-2012, 01:55 PM   #23
cliffyk
TECH SAVANT
cliffyk's Avatar
0.054"
"Pre-gapped" plugs are a myth, any plug manufacturer will tell you so. Modern manufacturing techniques allow them to be made with consistent gaps, however that gap may or may not be the correct gap for your engine--I.e. you have to at least check it, and change it if necessary.
This is from NGK's website (click here)
"Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
" [emphasis added]
cliffyk is offline   Reply With Quote
Old 08-08-2012, 01:15 AM   #24
kingrukus
I ended up checking all of my motorcraft OE plugs and many of them were way under 0.054"... anyhow I ended up adjusting them.
Old 11-05-2012, 10:50 AM   #25
sfmustang
sfmustang's Avatar
Question
On the passenger side, 2nd plug from the firewall its very hard to get to. There is the fuel rail I guess you would call it, but right at that 2nd plug from the back there is a T intersection from the rail to a connection piece that has a tube connected to it thats blocking access.
sfmustang is offline   Reply With Quote
Old 11-05-2012, 10:54 AM   #26
sfmustang
sfmustang's Avatar
I found this online to show what i mean.
Old 11-05-2012, 10:56 AM   #27
uberstang1
Chupacabra
uberstang1's Avatar
thats the fuel line to fuel rail connecion, the safetly clip comes off and theres a tool u insert to release the spring lock and then the line seperates from the rail. u should be able to change the plugs without removing any of the fuel stuff.
uberstang1 is offline   Reply With Quote
Old 11-05-2012, 11:04 AM   #28
cliffyk
TECH SAVANT
cliffyk's Avatar
Quote:
Originally Posted by sfmustang View Post
Question
I have an '03, identical under the hood to your '04--and have never found it necessary to break the fuel line to change that plug (which I have done at least a dozen times).
What "weapons" are you using? I use an extended deep 3/8" plug socket and a 10" wobble extension:
Using an extended socket makes it much easier as it will not cant or **** on the plug.
wobble extension:
Old 11-05-2012, 01:25 PM   #29
sfmustang
sfmustang's Avatar
Thanks guys. I'm going to have to give it another go tonight.
Old 11-09-2012, 09:11 AM   #30
sfmustang
sfmustang's Avatar
That worked. Thanks.
Labor Day Weekend Special Granatelli Sales GT S197 General Discussion 5 03-25-2016 08:01 PM
Spark Plug Change 2007StangV6 2005-2014 Mustangs 30 01-28-2016 06:09 PM
Labor Day Weekend Special Granatelli Sales The New S550 2015-2017 Mustang 5 12-27-2015 06:28 PM
Best Extreme Performance Summer Tires for our Mustangs? M3hunter S197 Handling Section 0 09-05-2015 03:42 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 10:45 PM
04, 46, 99, 9904, change, changing, cylinder, mustang, plug, plugs, removal, replacing, roush, spark, v6
