Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Replace Spark Plugs and Ignition Coils
Step by step instructions for do-it-yourself repairs
HOW TO: CHANGING SPARK PLUGS 99-04
#34
Cliffyk. I just replaced my plugs with Motorcrafts and all went well. Some of the plugs were looser then others. I used this http://www.norwalktools.com/ecommerc...plug-socket.py to torque my plugs as I don't have a 3/8's torque wrench (i thought my 1/2 drive TQ wrench was overkill). Am I correct to assume that this is sufficient for meeting the torque specs for the 4.6L? I read your review of this tool and this is what pointed me in this direction. I hope I did it correctly and don't have any issues.
#35
Careful when it comes to Anti-Seize. Some think you can use it like toothpaste. Just a LITTLE dab on the threads with the brush, spreading evenly. And NON on the seat of the plug, which could affect the torque setting.
#36
#37
Just so I am sure there is a very noticeable visual and auditory click where you reach the specified torque correct? The first time it did it I thought I snapped a plug or stripped the threads. Glad to know there is a break in period which i though because I could feel it happening but just wasn't sure.
#38
The spring tension is calibrated so that as you turn the input of the socket the ball "climbs" up the active ramp, compressing the spring; when the calibrated torque has been attained the ball falls off the peak of the ramp into the valley of the next. The socket makes a snap and releases when the ball falls off the ramp.
Because there are four ramps the socket has four active positions.
In theory you could just keep turning the socket as many times as you like and the plug would get no tighter as the torque is limited by the spring/ball/ramp action (I did test this using a digital torque adapter and found it to be true), however in practice there is no need to do this, one ramp-up and release is all that is needed.
So, as long as you turn the socket past at least one "snap" it is impossible to under- or over- torque the plug.
Pretty neat!
camlitlow
02-17-2015 03:40 PM
