Mach 460 + Subwoofer??
RE: Mach 460 + Subwoofer??
ORIGINAL: Sonicpilz
I have a 2000 Watt Orion 12 inch sub, with a 1500D watt RMS MTX amp. I pulled all wires and hooked it all up myself. I have the Mach 460 system with the factory 6 disc CD changer. All of the power, ground, remote wires you will hook up like any other system. You will need to buy a converter for your audio cables. The converter isn't much, I think like $40. Anyways the converter will make like a jumper on your rear factory speaker wires and convert it into the "red and white" audio cables that go into your amp. I'm not quite sure exactly which wires I connected, but I know they were exposed in my trunk under the speakers. It actually sounds incredibly good. I'll try to go out there and take some pics of all the connections I made.
DOes anyone want to buy any subs. I have two (2) MTX Thunder 8000 dual voice coil 12's, two (2) MTX 500 watt amps, a 2.4 Farad capacitor (to save the battery and alternator) and a box that is designed to fit into the Mustang trunk. I was gonna put hem in my car but decided against it. PM me if you guys want any or all of this system. I have all the necessary wiring except for the in line converter for the RCA outputs that you guys with the Mach 460 sound system would need. PM if you want pics of wanna make an offer.
breaking
10-02-2015 01:27 PM
