Changing 96 heads Q???
I am doing a head swap for my friend from 96 to 2001 specs from powerheads.com, he has all the parts supplied and I have done heads before on different cars, and was just wondering if there was anywhere I could find a good tech on swapping heads, so I don't get caught with my pants down. Thanks in adavance guys.
best thing to do is get a chilton manual. Then you will have all torque specs in front of you when you need them. Plus, the modular motor requires a torquing to a certain spec, then you must turn a certain number of degrees.... the degreeing depends on which bolts they are.
Luke9222
10-22-2015 11:55 PM
