car runnin lean...
Old 03-29-2004, 01:50 AM
RollinThunder
RollinThunder's Avatar
Default car runnin lean...
hey, I recently had my car dyno'd and it put out 228rwhp and 280tq but the dyno showed that my car was runnin really lean below 3500 rpm ...they guy said he could tune the car up and fix it but my sisters b/f is a mechanic and he told me to check my air filter and fuel line cuz it could b a clogged fuel line...
what r ur guys input on it and do u think that those hp and tq numbers r good for a stock GT even if its runnin lean?? thanks
RollinThunder is offline
Old 03-29-2004, 12:09 PM
pichinco
pichinco's Avatar
Default RE: car runnin lean...
Could be your MAF sensor is fouled. I've heard the dealerships use some type of alkaline solution to clean them. Don't use carb cleaner or something as it supposedly can mess 'em up good.
pichinco is offline
Old 03-29-2004, 01:01 PM
Greg00GT
Greg00GT's Avatar
1: Do you have the check engine light on?? if you do check for codes and fix it!!! it would really hurt your engine if you are running it lean!! If you dont have any codes I wouldnt worry about it.. you car's computer would detect any engine trouble right away!..
2: Yor hp and torque numbers look good for a stock 99+ GT [sm=smiley20.gif]
Greg00GT is offline
Old 03-29-2004, 07:51 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
I'd listen to the dyno guy far before a garage mechanic.
Dan04COBRA is offline
Old 04-02-2004, 08:30 PM
Casper98GT
I ♥ Acer
Casper98GT's Avatar
If youre car was running lean i'd check for codes, then from there check the air filter make sure its not clogged, then check the mass air, could be a little sometihng on it. but if anything was horribly wrong, the check engine light would come on
Casper98GT is offline
djbigskrilla
09-20-2022 01:04 AM
chain
08-17-2015 08:52 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: car runnin lean...
