Why are my tires so sticky??
Hey I've been sitting here trying to decide why I get so much traction. I can launch with only a chirp......DUMP it in 2nd with only a chirp and DUMP it in 3rd with nothing at all. I have 275's on the rear and 4.10's. I do however have a 12 inch 2000 watt sub and a 1500D watt MTX amp with a pretty big enclosure in my truck, plus the spare tire. I figure all this probably adds close to 100 lbs if not more in my trunk. Could all this have something to do with it?? If so, do you think I should take it all out at the track for weight reduction, or leave it in for traction???
RE: Why are my tires so sticky??
Are you absolutely sure your tires aren't spinning?
Just because they aren't squealing and making a lot of noise, doesn't mean they aren't spinning.
Mine don't make any noise whatsoever, they grab really well...but I've tore into them pretty good going sideways and screwing around a couple times. No sound at all usually.
ORIGINAL: Sonicpilz
Um....I've went through 2 sets of tires in the rear....1 up front. I know how to fishtail, doughnut, burnout etc. I also know if my tires are spinning or not.
What the hell was I thinking, I knew I shouldn't have left my crystal ball at home. [sm=icon_blah.gif]
ORIGINAL: Quickshift_02GT
ORIGINAL: Sonicpilz
with just a 3.73 gear and welded in flows (and a k&N lol) my car would just blow off the tires if I shifted hard into 2nd with my old BFG street tires.
The nittos fixed that problem though. I would just get a chirp in 2nd and thats it.
