Supercharger or PI heads???????
Old 05-06-2006, 06:51 PM
Guitarhead09
Guitarhead09's Avatar
Default Supercharger or PI heads???????
I have a 1998 mustang gt, cold air intake, hurst short shifter, 3:73 gears, racing clutch, 2" drop kit, Flowmasters 50's, ford racing ignition wires,
Im wanting some more power should i supercharger it or get PI heads?
Guitarhead09 is offline
Old 05-06-2006, 06:56 PM
Flyingmau5
Flyingmau5's Avatar
Default RE: Supercharger or PI heads???????
sc all the way bro =D
Flyingmau5 is offline
Old 05-06-2006, 07:20 PM
2000GT4.6
2000GT4.6's Avatar
S/c will net more than PI heads. You could port and polish yours later though to make more power.
2000GT4.6 is offline
Old 05-06-2006, 07:23 PM
03sonicgt
03sonicgt's Avatar
Personally, if I had a 96-98 gt, the first thing I would do would be a pi head/cam/intake swap. I would do all of that stuff first, then put on the supercharger.
03sonicgt is offline
Old 05-06-2006, 08:27 PM
hurleymasta
hurleymasta's Avatar
you cant do both unless you want to spend big bucks, cuz you get to a 10.1 compression as it is with the new pi heads on a non pi motor, so in order to blow it, you gotta lower the compressions and build the lower end
Ryan
hurleymasta is offline
Old 05-06-2006, 09:09 PM
Stang9946
Stang9946's Avatar
ORIGINAL: 2000GT4.6
About how much would it cost to have the heads ported and polished? (the npi heads already on the car)
Stang9946 is offline
Old 05-06-2006, 09:11 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: Stang9946
ORIGINAL: 2000GT4.6
Alot if you cannot pull the heads yourself. The port job itself shouldn't be much more than 800 or so bucks.
Old 05-06-2006, 09:53 PM
Stanghead96
Stanghead96's Avatar
port and polsih your npi heads and add pi cam and intake.....then you'll be rdy for the s/c
Stanghead96 is offline
Old 05-06-2006, 09:57 PM
Dragon02GT
Dragon02GT's Avatar
SUPERCHARGER first. The PI heads will only get you caught up to the new egde GT's. Get the supercharger and you will be over 300 RWHP easy.
Dragon02GT is offline
Old 05-06-2006, 10:40 PM
miglet
miglet's Avatar
or you could get an entire new engine, pi intake/heads stage 2 cams, put on a couple of small boltons like the tb/plenum and you have over 300rwhp n/a, and it also gives you the option to go with lower compression pistons/notched for that agressive cam and future supercharger.
- that is still cheaper than a full KB supercharger /w intercooler..
miglet is offline
Quick Reply: Supercharger or PI heads???????
