Coil on plug conversion 3.73/4.10
Old 05-07-2006, 11:18 PM
96gtwithpsi
96gtwithpsi's Avatar
Default Coil on plug conversion 3.73/4.10
sorry i brought you here under false pretenses but someone on here have to know. i tried using search but came up with no hits. i have a 96 gt that i am interested in doing a coil on plug conversion. the easiest source i've seen are 98 and up cop cars with 4.6. anyone know what this entails? probly the harness and the c.o.p but what else?
96gtwithpsi is offline
Old 05-08-2006, 12:21 AM
96gtwithpsi
Default RE: Coil on plug conversion
guess no one knows since it is not about an intake mod or another bolton
Old 05-08-2006, 12:27 AM
mustang_montana
mustang_montana's Avatar
id like some more info myself, cause my coil packs get in the way. im thinking of just going with an msd ignition though, which will be just as bad. i guess not many people do the conversion. maybe you should change the title to "3.73s or 4.10s?" thatll get some attention.
mustang_montana is offline
Old 05-08-2006, 12:40 AM
96gtwithpsi
i actually had an msd dis-4 on the car before but it wasn't all that amazing , and unless you mega gap the plugs you won't notice it. i just want to convert for the eficiency and the clearing up of room. no more coil packs, no more plug wires.
Old 05-08-2006, 01:06 AM
ghoste
ghoste's Avatar
Default RE: Coil on plug conversion 3.73/4.10
What does "3.73/4.10" have to do with coils?
Unless your asking ... Should I do COP conversion or do 3.73/4.10 gear upgrade, because if thats the case do the gears.
Won't notice much with the COP conversion unless your heavily modded, blown or sprayed.
EDIT: You have a 96... Not sure if there is a coil over plug conversion for that year? Someone correct me if I'm wrong, but you'd need new heads/intake manifold/wiring harness/computer if im not mistaken.
ghoste is offline
Old 05-08-2006, 01:30 AM
mustang_montana
ORIGINAL: ghoste
umm cause about a dozen gear posts are made per hour, and it was a joke to get more people to read this post. if anything involving the intake or wiring harness is needed to be swapped, count me the hell out.
Old 05-08-2006, 02:35 AM
Dark_Horse
Dark_Horse's Avatar
there is no point in doing that. you will need the ECU from a 99-04 4.6 motor and the tune in the PI Ecu is a little diffrent not much but a little. there is no point in doing this. you will recieve 0 HP from this. if your coil packs ar in the way then get some longer wires and move them
Dark_Horse is offline
Old 05-08-2006, 02:38 AM
monkeydude3
monkeydude3's Avatar
yeah that's right. however, there are previsions on the stock setup. I was looking at my manifold where the spark plugs go and there are the screw holes where you could bolt the coils. So if you really wanted to, you could convert. You are really not going to notice any problem. I've been studying ignition systems in school, and as long as your plug wires don't short to ground anywhere or have any opens, they will be perfectly fine
monkeydude3 is offline
Old 05-08-2006, 02:20 PM
96gtwithpsi
the car is blown so i guess i will have to look more into it. if its an easy swap i would do it just for the cleaning up the engine bay and not having to fight every spark plug boot for 30 mins to remove it. besides the fact how much more efficient and reliable a cop is versus a waste spark system.
Old 05-08-2006, 05:38 PM
monkeydude3
i guess it's more efficient... it's just to make things cheaper and more streamlined I guess. There really is no problem with a waste spark setup... we were analyzing it today in class
Quick Reply: Coil on plug conversion 3.73/4.10
