Trouble Code p0153 question
Hey all,
Im throwing code p0153, which tells me circuit slow response (bank 2, sensor 1) Wanted to double check with you guys I tried to reset the car by unplugging the battery and letting it sit for a few and clearing the code, but it comes on after about 2 starts. Does this mean the 02 sensor is on its way out or what thanks everyone?
RE: Trouble Code p0153 question
Doing that battery thing can only make your car worse by running rough till your car reprograms
itself, and with a bad o-2 sensor, that can't make matters any better.
Make sure you get motorcraft sensors. A bit expensive but they work better in pairs than with the Bosch.
They are roughly $60 for the motorcraft
and about$35 for the Bosch
Replace the sensor. You caould be running you car lean with a lower signal
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
