Good or Bad
RE: Good or Bad
Whenever there is enough rust to see on the surface on the car, there is always more hidden spots with nasty rust. I'd get the car up in the air, pull the carpet up in the trunk/etc to make sure you aren't buying yourself someones rusted out winter beater.
RE: Good or Bad
ORIGINAL: Dan04COBRA
RE: Good or Bad
RE: Good or Bad
i did look underneath the car the only thing that looked rusty was the exhausr which i figured from the heat and possibly the salt from the winters up there would cause that
but i do want to get it in the air
RE: Good or Bad
yeah im sure this place wont do that they sell there cars as is even though the mainly sell mercedes and bmws'
RE: Good or Bad
ORIGINAL: fiad06
Carfax it, i heard there is a way to check for flood damage, i found it kind of weird but the article said take your hand and check under your gauges for sand or other materials.check by the hood release button.
The easiest way I have found is to feel under the seats. If the wire springs feel rough and rusty it more than likely has been in water.
