fuel line and nitrous
Old 05-13-2006, 09:35 PM
ibeeskeef
ibeeskeef's Avatar
Default RE: fuel line and nitrous
Ok, maybe a really stupid question, but is the yellow circle in this picture what I am looking for. I don't think my car has any sort of port there. Also, what kind of valve is that in the green circle
ibeeskeef is offline
Old 05-13-2006, 09:43 PM
Voodoo
Voodoo's Avatar
ORIGINAL: bryanec
Look over the right head. There is an adapter that fits between the fuel rail and the vacuum.
[IMG]local://upfiles/20114/CFF36AD50B0447FB93688885D73A85B3.jpg[/IMG]
Where did you get that adapter? Doyou have a part#?
Voodoo is offline
Old 05-13-2006, 10:08 PM
bryanec
bryanec's Avatar
Nx sells them but I think they are only tapped on one side. Mine was a homemade copy and they tapped it on both sides (I work with machinists).
bryanec is offline
Old 05-13-2006, 10:10 PM
bryanec
bryanec's Avatar
I think the green circle is for AC.
bryanec is offline
Old 05-13-2006, 10:33 PM
Voodoo
Voodoo's Avatar
Oh I thought it was supposed to be installed on the other side in the fuel line. I have this adapter and I would rather hook it up there at the furthest from the fuel line in the second fuel rail to get a better reading. That sensor is actually the fuel pressure sensor for the computer. I wish they would have some instructions or even a little scetch of that damn thing. So that's why they give you screws for it. Ugh. Thanks
This is the fitting I have.
Voodoo is offline
Old 05-13-2006, 11:13 PM
Tac2cul
Tac2cul's Avatar
NOS makes an adapter for the service port
part#16785NOS
1/16NPTx1/8NPT FE Adapter
so there ya go
go grab a 1/16 NPT and make what ya want
Tac2cul is offline
Old 05-14-2006, 12:22 AM
ibeeskeef
ibeeskeef's Avatar
Ok, I have come to the conclusion that my car just does not have a schrader valve on the fuel rail. It must be one of the later '03 stangs that they stopped putting it on. So, I was going to tap into the fuel line using the fuel T fitting included in the kit in the spot I have circled below in the picture. Would this be a safe and usable spot?
Old 05-14-2006, 01:41 AM
dan
dan's Avatar
ORIGINAL: ibeeskeef
yes the yellow one is the factory test port. Not sure what the green one is. Factory test port seemed to be the easiest way to get fuel, without cutting anything.
dan is offline
Old 05-14-2006, 01:58 AM
Tac2cul
Tac2cul's Avatar
i have not cut the fuel inlet line but from what i heard its a plastic hose inside what you see...
a hose inside a hose so not sure how thats gunna work out....
Tac2cul is offline
Old 05-14-2006, 02:26 AM
bryanec
bryanec's Avatar
Cutting fuel lines can be bad. Just spend a little extra and get the adapter.
bryanec is offline
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: fuel line and nitrous
