1)pop open hood
2)remove clips and take off heatshield
3)remove 6 bolts and take off hood scoop
4)dremel the holes in the hoodscoop
5)put blanket over your engine to make sure no pieces get in it.
6)when you removed the hoodscoop you will see an oval dremel out the oval. in the picture the oval is in black
7)put the heatsheild back on and mark where the hole is then cut an oval out of the heat shield.
8)put heatshield and hoodscoop back on and now your hoodscoop is functional.
It's not really "functional", but a drilled and cut hood does keep the upper manifold chilled pretty decently. Just don't drive in a tsunami or anything.
