OMG I THINK I AM SCREWED
Old 05-17-2006, 07:53 PM
djb1187
djb1187's Avatar
Default OMG I THINK I AM SCREWED
I am about to cry i cant figure out what to do. I have a 01 GT and i have the coil on spark ignition and I tried to check one of my spark plugs and i didnt even take the spark plug out but i put the wires back in and put everything the way it was. WHen i started it up it was barely missing. Now i checked it again to see why it was missing and i accidently stripped the screw holding the spark plug wire in place. It is now extremly missfiring and my CEL like is on! i hope i do not need a new intake manifold. Please someone help me....
djb1187 is offline
Old 05-17-2006, 08:41 PM
Mt Twigbert
Mt Twigbert's Avatar
Default RE: OMG I THINK I AM SCREWED
Couple of photos to show exactly what you did and what you need help with would be great..
Mt Twigbert is offline
Old 05-17-2006, 08:48 PM
Emann0007
Emann0007's Avatar
ORIGINAL: Mt Twigbert
what's with all the red buddy?
Emann0007 is offline
Old 05-17-2006, 08:52 PM
NORTON98
NORTON98's Avatar
How can the screw holding the wire in place have that much impact on the engine... post some pics for sure!
NORTON98 is offline
Old 05-17-2006, 08:58 PM
Black on blacK
Black on blacK's Avatar
without seeing what your talking about, i would try just going to a hardware store and getting a tapp and dye set to fit that size hole and trying to re-thread it myself before i went pricing new manifolds.
Black on blacK is offline
Old 05-17-2006, 09:24 PM
djb1187
djb1187's Avatar
heres a pic, its the 1st spark plug on the right. The gold screw to the right of the spark plug thingy is the screw that is stripped. if needbe ill circle it for you guys.
djb1187 is offline
Old 05-17-2006, 09:32 PM
ackuric
ackuric's Avatar
i did the same thing dude, because my new manifold had 2 of those untapped, so i tried, but didnt do it quite properly...
anyways my cars running fine so i dont plan to do this soon, but what im going to do is...
put jb-weld into the screw hole, let it set for a day (yes no driving for a day) then get a proper tapping set, and tap that hole nicely with the proper sized bit, and walla, you are set, well, i will be.
ackuric is offline
Old 05-17-2006, 10:27 PM
ghoste
ghoste's Avatar
Well, If I were you, I'd replace that plastic manifold and get the aluminum x-over... BUT
If you think you'd have to buy a new manifold because you stripped the threading, then have someone install a new manifold for you.
If you want to keep the manifold you have (factory defect), then like Black on Black said re-tap the hole.
ghoste is offline
Old 05-17-2006, 10:54 PM
Aixtreme89
Aixtreme89's Avatar
If I were you, I would turn the car off and unhook the negative cable from the battery. Then take a flat head screw driver and pry it under the coil pack and the metal threaded sleave holding the bolt on. then try unscrewing the screw. I think what is happening is that the sleeve is spinning in the plastic manifold. That would give way before you would strip the treads on that sleeve. Thats the only way I can think of getting it off. As for your ignition problem, the bolt wouldnt have anything to do with it since thats not a ground. I dont think you but any die-electric greese on the plug so your getting resistance in your wires and its not sending your plug a full spark. Good luck.
Aixtreme89 is offline
Old 05-17-2006, 10:56 PM
so1o2k3
so1o2k3's Avatar
I'm not sure if this would help in your case, but when you put the screw back on try putting some teflon tape on it.
so1o2k3 is offline
Quick Reply: OMG I THINK I AM SCREWED
