Best modd under 400 dollars?
#41
RE: Best modd under 400 dollars?
ORIGINAL: stanggang1892
4.10's end of story...............go big or go home dont mess around with 3.73's you will just kick yourself in the head later
#43
ORIGINAL: 97targa
GO 3:55'S FOR OVERALL GAIN.
ORIGINAL: Spectre062
Just curious, but would 3.73's make better street/road course gears? I could care less about 1/4.
#45
First mod? TIRES TIRES TIRES TIRES TIRES TIRES!!!! I dropped .3 off my 1/4 when I swapped to drag radials and probably could have made it slightly more then that to be honest. Either gears or tires.. but you need BOTH to really get a good launch at the strip.
#46
ORIGINAL: cwm1230
The best mod for the money at your price would be a gear swap.
If you have a automatic do a 3.73 gear.
If you have a standard do a 4.10 gear.
The if you do a bigger gear than a 3.73 on a automatic your asking for Tranny Problems.
I had a 2002 Mustang 5 speed Manual and I put the 3.73 gears.
And if you really want to feel the power you need to do a supension upgrade.
Adjustable shocks, subframe connectors, springs, and control arms. You won't believe the difference it
makes by changing these parts. It drive completely different and it stiffens the frame and allows you
to put more power to the ground which will improve your time.
ORIGINAL: 97targa
Matt's 95 Stang
10-05-2015 07:16 AM
