Codes
Codes
my check engine light was on for a few days and it has done it for like a day and gone off. but it didnt go off so i put the scanner on it and got these codes P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault,
and P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)... what should i do now i mean im gonna asume one of my 02 sensors is bad but what about the first one?
RE: Codes
There is a valve that if you fill your gas tank up too far it gets gas in it and the valve goes bad.
My car is running the same code right now. The part to fix it is like 30 bucks i think but its more of a pita than anything bc its in the fenderwell.
I did a search a few weeks ago and couldnt find a definitive answer on any mustang boards but this seems to be a very common problem with rangers.
lincolnshibuya
12-08-2015 04:37 PM
