stage 3 cams
05-18-2006, 11:42 PM
stage 3 cams
In order to install stage 3 cams for my 4.6 2v, what would i have to do to make the motor handle it or use the cams full potential?
05-18-2006, 11:49 PM
RE: stage 3 cams
heads, built bottom end. and maybe a intake manifold i think
05-18-2006, 11:50 PM
RE: stage 3 cams
When you say heads... you mean buy new heads?
05-18-2006, 11:53 PM
RE: stage 3 cams
you can port and polish.
05-19-2006, 12:04 AM
RE: stage 3 cams
Or buy aftermarket performance heads. Either way it's going to be roughly the same amount......extra expensive!!
05-19-2006, 12:25 AM
RE: stage 3 cams
why did you order cams with out looking into what it would take??
05-19-2006, 12:34 AM
RE: stage 3 cams
you cant put stage 3 cams in your motor without having your pistions fly cut....trust me i learend the hard way......if u have any Q's just pm me
05-19-2006, 01:40 AM
RE: stage 3 cams
My answer to everyone except willyd465 is thanks for the info, to willyd465, where did i say i bought stage 3 cams?
05-19-2006, 02:14 AM
RE: stage 3 cams
along with the forged internals, heads, intake manifold
give the guys a call at
vt engines a call and they could help you out
know you said just engine stuff but thought I would add the other stuff
Also recommended would be exhaust, and gears . If you are auto, you will need a stall.
You would have to have a dyno tune
05-19-2006, 02:21 AM
RE: stage 3 cams
take all that dough and put it on a supercharger and then buy a motorcycle with the money you will have left over.
