does your MAF have to be the same size as your T/B
Old 04-07-2004, 06:55 PM
yellowstang98
yellowstang98's Avatar
Default does your MAF have to be the same size as your T/B
i was wondering if i could run a 80mm maf and then have the 75mm accufab t/b and plenum? if so what would be the hp gain over getting say a 75mm maf, and another thing-where can i get an 80mm maf? thanks
yellowstang98 is offline
Old 04-07-2004, 07:16 PM
w11988
w11988's Avatar
Default RE: does your MAF have to be the same size as your T/B
your MAF and TB don't have to be the same size. I believe the standard C&L MAF that comes with their kit for 98 GTs are 80mm. I'd have to look again to be sure though.
w11988 is offline
Old 04-08-2004, 12:27 AM
VertStangGT86
VertStangGT86's Avatar
It's not a huge deal. If you've got the stock throttle-body and like a huge mass air it's not gonna do a whole lot, but those two should be fine.
VertStangGT86 is offline
Old 04-08-2004, 01:45 AM
04ShakinSteed
I ♥ Acer
04ShakinSteed's Avatar
They don't have to be the same size. Are you sure your car takes the 80mm though? I know the 00,01,&02s take the 80mm. Check into that, you can't just put on any size Mass air meter on that you want.
Also, just changing out the TB will not do any good unless you also change the plenum.
Info on MAF:
www.cnlperformance.com
good place to buy:
www.crmotorsports.com
good luck
04ShakinSteed is offline
Old 04-08-2004, 02:40 AM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: VertStangGT86
Not true. You dont need a giant MAM nessicarrily, but accoding to dyno tests the T/B makes a fairly small difference. I have seen dynos of a C&L kit (thus MAM) making 12-15 more HP, and then after adding a larger T/B gaining only an addiotional 2-3 HP.
2000GT4.6 is offline
foxtrot
09-29-2015 06:32 AM
mungodrums
09-28-2015 05:45 AM
09-25-2015 06:30 PM
Demodulates
09-18-2015 11:14 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: does your MAF have to be the same size as your T/B
