check engine light
Old 05-19-2006, 11:56 AM
MustangMan528
MustangMan528's Avatar
Default check engine light
i just installed me new exhaust a few weeks ago and when putting in the new prochamber, i was only able to get 3 of the 4 02 sensors connected. the fourth one, i didn't have enough slack in the wiring to screw it in. anyways, my check engine light just came on the other day, but the car seems to be running fine. what is the probability that it's just b/c my 02 sensor isn't connected????
MustangMan528 is offline
Old 05-19-2006, 12:38 PM
shadowfoxx
shadowfoxx's Avatar
Default RE: check engine light
I'm sure the reason is because the 02 sensor is not on but you really need to get it put on.. the car will start to not drive as well with it off.
shadowfoxx is offline
Old 05-19-2006, 03:14 PM
MustangMan528
how will it begin to not drive as well?
Old 05-19-2006, 03:28 PM
rbstang
rbstang's Avatar
is it catted or o/r prochamber? and which 02 sensor is it?
A)Driver side before cat
B)Driver side after cat
C)Passenger side before cat
D)Passenger side after cat
rbstang is offline
Old 05-19-2006, 04:44 PM
shadowfoxx
shadowfoxx's Avatar
I have heard that when the car detects a problem with the o2 sensors it will start to go into a type of "safe mode" which retards timing etc..
Old 05-19-2006, 05:21 PM
JT76
Moderator
JT76's Avatar
by turning the sensor off with , say a predator, willl solve this "safe mode" problem correct
JT76 is offline
Old 05-19-2006, 06:27 PM
shadowfoxx
shadowfoxx's Avatar
yep [8D]
Old 05-20-2006, 12:49 AM
tcuallstar
tcuallstar's Avatar
ORIGINAL: stanggang1892
ok, theoretically, if i have my stock h pipe and i turn off the o2 sensors with it, will it not going into "safe mode" make me a little more power?
tcuallstar is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: check engine light
