advice plz?
Old 05-20-2006, 02:37 AM
so1o2k3
so1o2k3's Avatar
Default RE: advice plz?
280 lol..wow my usual temperature is around 180 so i guess I could just get the 5w-30, but when I was at Wal-mart the only 5w I saw was the 5w-40. Will that be okay too?
so1o2k3 is offline
Old 05-20-2006, 02:38 AM
cobrapony27
cobrapony27's Avatar
87,000 miles is not all that much, these motors are built with about .0008" (8 ten-thousands) of clearance in the main and rod bearings, you have maybe worn .0001"-.0002" off the bearings. Once you get around 120,000 on switch to the 10w30.
cobrapony27 is offline
Old 05-20-2006, 02:40 AM
cobrapony27
5w-40 would be fine, what that means is it when it gets hot it will get not thinner then a 5 weight, and when its cold its not thicking then 40w, and living in florida i think it would be safe to say it want get that cold.
Old 05-20-2006, 02:45 AM
so1o2k3
so1o2k3's Avatar
hey thanks a lot man, you really know you're ****.
so1o2k3 is offline
Old 05-20-2006, 03:09 AM
rjgstang
rjgstang's Avatar
dont they take 5.5 quarts?
ORIGINAL: ironh19
a wrench or one of those filter claws work just fine for the filter and the oil drain plug is a 5/8 and your car should only take 5 quarts of oil.
rjgstang is offline
Old 05-20-2006, 03:15 AM
cobrapony27
it can vary from car to car, thats the down side on fords, they can vary their parts sometimes. iv seen a 4.2 v6 take 8 quarts, didnt believe it, so I paid for the 8 quarts my self, drained it, and had some one else to fill it to make sure, sure enough took 8 quarts. Others have only took 6.
Old 05-20-2006, 03:26 AM
Hyper00
Hyper00's Avatar
Before you use the oil filter wrench, try with your hand first. You should beable to loosen and tighten it with your hand(unless I have monkey grip). Then bring the wrench back to the store.
Hyper00 is offline
Old 05-20-2006, 12:15 PM
so1o2k3
so1o2k3's Avatar
Just got done changing the oil. I used my leathery man hands to grip and get the oil filter off and out It's actually very easy to take off because of the room you have and leverage you can get under the car. In my 1.8L mazda that was a different story [:@]
To my surprise, the car only took 5 quarts even when I let the engine run for 20 min and checked the oil again, it was beyond the maximum oil level. odd...
so1o2k3 is offline
Old 05-20-2006, 12:36 PM
ironh19
ironh19's Avatar
you know its the weirdest damn thing, some cars do take 5.5...mine take 5, my friends take 5, another friend of mine take 6. I think in 2002 it switched to 6 quarts. I spent 6 months as a lube tech for ford and then for a local shop....its amazing how much you can learn in 6 months. Especially like that other dude said there is a 4.2 out there that takes 8 quarts. I went through every book and even called the local parts store to confirm that number.
ORIGINAL: rjgstang
ORIGINAL: ironh19
ironh19 is offline
Shadow7874
09-24-2015 09:06 PM
2k232
09-16-2015 10:28 AM
EASTIDEE123
09-15-2015 11:08 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: advice plz?
