What to do with the automatic tranny?
Old 05-20-2006, 12:10 AM
JT76
Moderator
JT76's Avatar
Default What to do with the automatic tranny?
as we all know the Automatic transmission that they threw into the mustang is a piece of crap. After seeing my dyno numbers and realizing that i am getting 249rwhp out of around 300 at the crank it made me realize how crappy it is. Is there anything that can be done or is it a lost cause?
JT76 is offline
Old 05-20-2006, 12:19 AM
ackuric
ackuric's Avatar
Default RE: What to do with the automatic tranny?
the right torque converter will give you around 20ish rwhp back =)
i think its due to a lot less rotating mass in the drive train, not sure how close to 20 you will see, 10-15, 20 if your lucky
ackuric is offline
Old 05-20-2006, 12:23 AM
GreyStang
GreyStang's Avatar
& get a shift kit
GreyStang is offline
Old 05-20-2006, 12:39 AM
JT76
Moderator
JT76's Avatar
anyone know where to get one ^^? about how much money will that run......15-20 hp, i'll take it
JT76 is offline
Old 05-20-2006, 01:20 AM
ghoste
ghoste's Avatar
$750ish for a good torque converter and around $90-100 for a good shift kit.
ghoste is offline
Old 05-20-2006, 03:40 AM
ackuric
ackuric's Avatar
the install for shift kits will run 3-500$, and the tq. convertor, mmm, i'd say bout the same.
i have a shift kit and love it, cant wait for the tq converter, just need the money. im pretty sure you dont gain that hp either, its just something you get back from drivetrain loss. i dont know if all tq convertors are the same but i saw one with dyno's showing it gained 15-20 hp
ackuric is offline
Old 05-20-2006, 03:50 AM
93BlackNotch
93BlackNotch's Avatar
Torque convertors actually decrese dyno numbers... Shift kits don't increse horsepower, they just make the trans shift faster and a bit harder... It's not about what numbers you put down on a dyno, it's about what you run at the track...
For instance, I have a friend with a 700hp Supra that runs high 10's, but my other friend has a 500hp, low 9 second Mustang.... It's all about how efficient the car is and how your parts work together... Good luck
93BlackNotch is offline
Old 05-20-2006, 03:55 AM
93BlackNotch
ORIGINAL: stanggang1892
Also you have to remember those cars are rated at 260 to the crank... You are making decent numbers for a bolt on car... I'd say your numbers are close to right, I wouldn't complain if I was you If you figure you are losing 15% through the drive train you are making around 287 at the crank.... 27HP out of a few bolt ons are pretty impressive...
Old 05-20-2006, 04:00 AM
ackuric
ackuric's Avatar
i didnt say my shift kit added hp, i know its function
yes the right tq converter will give you hp/tq back from drivetrain loss, i read an article about it, ill find it tomorrow for the genius.
ackuric is offline
Old 05-20-2006, 04:01 AM
93BlackNotch
Ahhhhh.....
Quick Reply: What to do with the automatic tranny?
