PI swap
RE: PI swap
ORIGINAL: Zoie_daGT
hahahahah Right when I finished typing that I looked at your post and thought the same thing. I just wanted to post since I took all that time to type it out. If you want, I will edit and cite you in my response or post a works cited w/ you in it. hahahaa
RE: PI swap
ORIGINAL: amoosenamedhank
I'm not really sure what your talking about with the mustang tuning thing. But I did a pi swap and found a set of heads and had them check by a machine shop for $500. Intake for like $200. I had to grind valve reliefs in my pistons, so that was free(most people just fly cut the pistons which you will have to pay for either way). $100 for a head change kit, and like $180 for valve covers. You will also have to re-route your heater hose coming out of your water pump, and move your engine temp sensor somewhere else because there isn't a bung for it in the pi manifold.
(I know the performance gains are more with PI heads)
Matt's 95 Stang
10-05-2015 07:16 AM
