Diablosport Maf.ia.
Diablosport Maf.ia.
Ive been wanting to get a larger mass air sensor for my pony, but with having a cold air intake, it is hard to just find the actual mass air sensor apart from an entire kit. dont get me wrong, ive found stand alone ones, so i dont need any links, but, i did come across the diablosport maf.ia. has anyone heard seen or used one of these before? it sounds good, but i just dont know if its what im looking for. advice or opinions would be a good start for me. would good gains be pretty likely from one of these? thanks, zac ----- here is the info about the Maf.ia. you can see the actual site at diablosport.com... The MAF Interface Adapter allows one to use the stock MAF sensor with a supercharger or in any higher horse power application. The MAF interface adapter plugs directly to the stock MAF harness and into the stock MAF sensor. The MAF interface takes only seconds to install.
The MAF Interface recalibrates the signal output from your stock or aftermarket Mass Air Flow meter to increase the range before the MAF is maxed out.
* Works with 4 & 6 wire MAF sensors
* MAF interface has 8 selectable settings for stock to high horsepower levels
* It has a led indicator to show if the MAF sensor has reached the max voltage (pegged).
* The MAF interface extends the stock MAF wire harness length, so it can be used as an extension.
t3000
05-10-2005 09:03 PM
