Launch and shift points
Old 04-13-2004, 01:14 AM
Razor19
Razor19's Avatar
Default Launch and shift points
I got a 96 GT, what should I revv up to when I'm launching and when I launch should I dump the clutch or feather it? Also at what rpm should I shift?
Razor19 is offline
Old 04-13-2004, 03:31 AM
RollinThunder
RollinThunder's Avatar
Default RE: Launch and shift points
just practice launchin in on a back road until u find what works best for u and ur car...and as for shift points if ur racing shift at redline
RollinThunder is offline
Old 04-13-2004, 05:29 AM
2001SilverGT
2001SilverGT's Avatar
i launch at 2500 RPM's .. but each car is different .. make sure the car doesn't bog down when you dump the clutch
try it a few times on a back road like Thunder said
2001SilverGT is offline
Old 04-14-2004, 01:11 PM
Chopper
Chopper's Avatar
When racing my H-D,I like to feather the clutch with wide open throttle.I have tried feeding power and clutch to keep wheelspin to a minimum in my GT and found this to give the best "seat of the pants" acceleration(I haven't raced it yet, only 1700mi).Dumping the clutch is good for smoky burnouts and fried tires,but does little to lower ET's.The method with the bike has won many races against crotch rockets because they want to wheelie and usually will let off the gas instead of pulling in the clutch,and by then it's all over. The key is horsepower management ,max power to the ground and stay in control of the power.
Chopper is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
TCStangerv6
10-11-2015 05:57 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
Quick Reply: Launch and shift points
